New location to hang turbos in
#196
After my next dyno/street pulls we will know. I am told now that at 16 volt it will support 1250 wheel E85. fingers crossed.. 16volt battery, step up transformer to charge it and pump is on its own system. Lets see..
#198
Tim are you running the fuel pump controller as well?
http://www.weldonracing.com/product/...ontroller.html
I run Autozone battery in my car right now and it has no problem with my power on this pump. I've never even considered a 16V setup because of the converting that needs to be done. We run them on race cars all around down here, but no alternators. Plus it's not like the car is even a dyno queen (but now 3 matching dynos) the numbers I've ran verify everything.
Something just seems off with a lot of the problems. I know you are getting most solved but trying to give some information with experience with this style setup.
Keep up the bad *** work regardless its changing non stop!
#202
that thing is moooooving for 20psi
#TeamAIM
#TeamAIM
#204
Congrats on having it up and running,she sounds good!One question are u saying you are making 1200 whp @ 20 lbs of boost on e 85?if so that is the most efficent 996/997 turbo engine in existence that i can tell uWhat size fuel lines are u running supply and return?
