Put bigger turbos on...car makes less power
Old 07-11-2012, 07:11 PM
Tim941NYC's Avatar
Blue smoke yes, not white smoke.
  #32
Old 07-11-2012, 08:57 PM
for whatever its worth when my turbo accord with a built motor burnt a ring and broke a ringland it had ZERO smoke. just loss in power. i hope thats not the issue here !!
#TeamAIM
  #33
Old 07-12-2012, 09:00 AM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
yeah me either that would suck
ajay...its smoking one every startup..warm or cold. Smoke is white...mostly smells like fuel but its hard to tell sometimes
mechanic pulled plugs yesterday and is checking heads and will do a compression test today
  #34
Old 07-12-2012, 09:20 AM
32krazy!'s Avatar
blue smoke is oil blowby, white smoke is water, ie head gasket
  #35
Old 07-13-2012, 09:31 AM
bad107's Avatar
compression tested at 170 across all cylinders...leak down of 5-8%
going to try some vp109 fuel instead of this shell 110 octane...this might be causing some tuning issues
put new plugs in and drained the tank...will test later today
  #36
Old 07-13-2012, 09:44 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
What time are they going to dyno? I will stop by.
  #37
Old 07-13-2012, 10:21 AM
bad107's Avatar
not sure when...bring some magic beans with you to sprinkle on the car please
  #38
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
get video. Use your iPhone. Directions: Press the camera app. Move slider to "video". Press the record button (red button in the middle). Post on youtube.
  #39
Old 07-13-2012, 12:33 PM
Tim941NYC's Avatar
Too funny.
  #40
Old 07-16-2012, 07:00 AM
How did the dyno go on Friday?
  #41
Old 07-16-2012, 10:37 AM
bad107's Avatar
a bit better but still very low on the power
we are going to take off the mufflers and try it once without to see if somehow the exhaust is causing any issues
i am 99% sure they already checked this, but per tim's suggestion, have them check to make sure its properly going into high lift
if without the muffler is not different i am going to just have them just fab up some fender intakes and i will actually drive it...it could just be the dyno/tip combination
  #42
Old 07-16-2012, 04:10 PM
bad107's Avatar
took muffler off and no additional power
i would drive car on the st but it would have to put back together and fender intakes fabed up....mechanic says car feels underpowered and the dyno doesn't lie (has had 3 other cars on dyno recently).
he checked high lift at idle and it seems to be working fine
we are out of ideas...he made sure no intake leaks, engine was compression and leakdown tested, logs look ok...timing could be improved but we are just too far off, and we just tried without the muffler to eliminate the exhaust variable...
  #43
Old 07-16-2012, 04:18 PM
Ben, my car (old tiptronic) never dyno'd more than 550 with 24/18's on Steve's dyno. I bet it's fine. Just put it back together and let's do a 65 roll.
  #44
Old 07-16-2012, 04:19 PM
bad107's Avatar
steve says the car feels very slow (not to mention the dyno numbers) and putting the car back together would be counterproductive...
  #45
bad107's Avatar
65 roll? I'm no dummy...I am only racing you 0-60
Quick Reply: Put bigger turbos on...car makes less power
