Help! Engine Compartment Lid light is "ON"!
Something is weird, I came down to the garage last night and the engine compartment lid light is on. The bulb was hot and burnt my finger to the touch. It was on for several hours. I did not open the hood/boot since the afternoon. I can't find a switch to turn the bulb off, so I had to remove it.
How does the engine compartment light goes off, when the hood is closed? There's got to be a pressure activated switch somewhere. I looked for an electrical diagram and searched the thread. Does anyone know? Any help would be appreciated.
Had the same thing happen and was worried it was draining battery do pulled the bulb!
Let us know what you find, but all of my doors/hood had been closed as well. Who knows how long it was actually on.
Loren at Renntech said there's a micro switch in the latch. I checked the price for a new latch and it's around $200. Does anyone know if he micro switch can be removed and replaced instead of the whole latch assembly? I may just leave the $1.29 bulb out and use a $3 LED flashlight.
Anybody know if you can connect battery conditioner in through the cig lighter? My maintainer has cig adapter and I do that for my Superduty diesel without issue.
Also the rubber strip at the inside edge of the engine compartment that blocks the gap when engine lid is closed looks like some chemical made it swell and has to be manually guided to stay inside as engine lid is being closed. Is that a dealer-only item?
Thanks in advance
Thanks in advance
New to me 04 996tt cab is doing the same thing (stays on even with hood closed)
Thanks in advance
Thanks in advance
Can't help with the light on - haven't had that issue. Did you make sure your armrest console cover is closed too? A lot of these things are connected even though you wouldn't think they are. What about instrument panel lights - turned up all the way to on? Just grasping....
Thanks in advance
Thanks in advance
The lid seal looks as if it has gotten longer with time and it won't straighten out well enough to slide back under unless it's guided as you suggest. Is this a dealer only part? I looked at Pelican but didn't see it anywhere
I gotta say I was reading various threads on here for a couple months before the deal was finally closed on the car and found it quite helpful. I'm an offshore powerboater and have for years relied on the community to share good info and experiences so it looks like I'll have two stops online each day.
ECS Tuning - BMW
08-21-2015 02:00 PM
