996tt vs 997tt
I would recommend test driving both.
I couldn't tell the difference performance wise between my 996TTX-50 and the 997. One of my buddies called all excited when they first came out, so we went over to Rusnak for a test drive. I pushed the car hard from 0-60 as well as the higher gears and took it up to 130 mph...the saleman didn't flinch, so I take it that he gets it all the time.
Though if you post your question on the 997 Board, you'll likely get a different answer.
Hi,I think a 997 turbo is a better base if you were into going with basic mods OR to the other end with big mods..
But you will pay more for the 997 turbo which I believe is a better all around car also ,so you have to decide...
Good Luck..
Good Luck..
I also found that my 996TT's PSM system was much more intrusive than my 997TT. I think many drivers who went from a 996TT to a 997TT find the same.
But seriously, in a side by side run, I found my 997TT consistently faster. It trapped consistently higher, and has a 0-130 mph about 1 second faster.
...true...which is why you should ask someone who's owned both.
Well at least with a 2002 996 T the manual says my car weighs 3394.9 lbs (3494.1lbs for a tip). My downloaded 2005 2005 brochure says 3505 (3594 tip) so it gained a little weight since it had first come out. So at least at first the 996 T was about 100 lbs lighter.
About the 997T handling, it comes up in Excellence Dec 2009 talking about how the 2010 addresses the criticisms of the turbo before it. It doesn't say the 996 turbo handles better so my favoring 996 turbo so that part is IMO at least especially with the option to add PSS10's and 996 Turbo owner bias :-)
This really isn't difficult. I wish people with 997T would stop talking about how 997T isn't heavier!
All that needs doing is to check 996T manual versus 997T manual. Weight demistified!
996T 1540kg, 997T 1620kg.
This translates into 997T/996T stock bhp per tone; 296 versus 272 making the difference of merely 24bhp.
One poster stated that his x50 car feels the same; he is right. The difference between 996TS and 997T is NEAR ZERO! 5BHP advantage to 997T!
I am now getting some pop-corn too!
For any kind of modding, 996T is a better platform because of the initial lower price, this is a no brainer and everyone knows it.
No, the spare fits in back, you're just not supposed to drive it that way. It looks really narrow when mounted on the back!
Owned both: Two 996s and one 997. The truth is, the 997 is better in pretty much every way. Anyone who has owned both will tell you the same thing.
That said, the 996 is still a world-class car, especially for the prices that you can pick them up at these days. Can't go wrong with either. It really comes down to how much you want to spend.
Actually, if you want to get technical, I weigh my car next to 997T’s every time I go to the track. 997T’s actually score much worse than what I have put - the book value. There is a constant 80-100kg in favour to the 996T's.
You think and believe? Not very scientific now is it? Also, better base for small and big mods? A bit of contradiction in terms don’t you think?
And yes you will make more HP/TQ on just a flash/exhaust on a 997 Turbo over a 996 Turbo with the same >> Small mods..
And if you go big mod set-up,you have a better intake track,heads and strength over a 996 turbo...
So, thats my thoughts.....
