Dyno Test Throttle Body Set-Up Friday..
#46
HI,So far got this to show from Porsche,,
Blue 9, 74mm, Verses Red 6, stock >>The first beginning good runs
Blue 10,74mm, Verses Red 8,stock >> The middle runs,right after the first runs,,,heated up-lost power
The dealer first put on the screen Red 8 and Blue 9....I was happy ,then I compared my notes..
#47
Pics for John:
http://www.flickr.com/photos/11298777@N08/7736683460/http://www.flickr.com/photos/11298777@N08/7736683460/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736685116/http://www.flickr.com/photos/11298777@N08/7736685116/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736687098/http://www.flickr.com/photos/11298777@N08/7736687098/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736689286/http://www.flickr.com/photos/11298777@N08/7736689286/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736690870/http://www.flickr.com/photos/11298777@N08/7736690870/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736692768/http://www.flickr.com/photos/11298777@N08/7736692768/ by http://www.flickr.com/people/11298777@N08/, on Flickr
http://www.flickr.com/photos/11298777@N08/7736681298/http://www.flickr.com/photos/11298777@N08/7736681298/ by http://www.flickr.com/people/11298777@N08/, on Flickr
#48
John,
Your signature says AWE intercoolers. Don't they supply the hoses that neck down to an OEM fitting for the OEM Y-Pipe? If you are using those necked down hoses, you have a bottleneck at the Y-Pipe and the larger throttle body will not receive all the air it could, if you had full 2.5" hose & 2.5" Y-Pipe legs to a large, 75mm outlet on the "Y" to flow match the TB. I'm not sure exactly what you have, I'm just guessing, but if this is the case, you may want to further modify the intake track to maximize the air flow.
2001 996TT 3.6L and stock ECU
#49
John,
The AWE hoses are around 2.75"..
Protomotive modified the stock Y- pipe trunk to match the throttle body.
#50
I really didnt feel any driving difference or seat of the pants on the street/X-way BUT when I left the shop it was also hotter and more humid out as compared to the few days before going there..
When I got home ,about 20+ miles away mostly X-way,the idle would creep up to a steady 1200 RPM so I brought it back...
So now I am going to watch the gas mileage,yes I am a Polish..lol, and if it takes a noticable hit >>I might put the stock stuff back on??
Hmmm.....Maybe my set-up might work with K24/20g's now...
#52
if your idle creeps to 1200 you got a vac leak. since there were "in there" yesterday and problem start - you definetly got a vacuum leak !
#TeamAIM
#TeamAIM
#53
John, you mentioned the plenum was modified...What did you do to it? it looks like you got the effect from the larger T-body but not the low end that the IPD gives.
I agree with Markski, great on big HP cars and I have always run one too.
#54
plenum
I do have to say when the product first came out we (when I was at Speed Gallery) did over 30 of them in a few months and were involved when it was being developed. I have seen gains on 500hp cars as well. Mainly seen faster response and mid range due to the diverter. On 500hp cars with the 74mm set-up we saw a top end spike too. I can vouch for their posted dyno's.
#56
#57
GL
Tom
#58
But it didnt,it idled perfect..I ran it hard on the way home to see if I felt anything different in power..When I got off X-way by my house it had the idle problem..A steady higher idle is usually is not a bad enough vaccum leak to affect wide open power??
It was a small hose that popped off the aftermarket fitting..
When I get out of the firehouse tomorrow I will pick the car up and see which one it was..
#59
I zip tied every one of them the last time my engine was out. I am a huge believer in pressure testing your engine, both after a mod,and I do mine at every oil change.
It only takes a few minutes and you would be surprised how many little things can leak. A pressure test kit, soapy water and a automotive stethoscope, will reveal a ton!
Tom
#60
One of those 3 little vacuum hoses on the left front side of the plenum popped off..
Now it idles perfect like when I first left the shop.
Its cooler today and I drove home mostly on main roads, no X-way.
I feel the gas pedal is a little more sensitive, part throttle is crisper and only if I floor it at higher RPMS it feels like it hits harder.
