19" BBS LMs?
19" BBS LMs?
So I called Tirerack today to ask why they don't display the BBS LM wheel when you look up wheels for an '01 Turbo. I talked to a guy named Clark, he said that the particular wheel doesn't fit in the front because it rubs the caliper. Does anyone have any more info or actually have these wheels?
I researched BBS to see what fitments they offer on the LM 19".
For the Front:
The front fitment they offer is 19x8.5 +50mm offset model #LM 169 – DSPK. They do offer a +55mm offset wheel which I suspect is the one that rubs the front caliper. With the +50mm, you could easily run a +10mm spacer, which would net to a 18x8.5 +40mm (996GT2 front wheel spec).
For the Rear:
The rear fitment they offer for the WB car is 19x11.0 +50mm offset model #LM 199 – DSPK. This wheel will work, but you could easily run a 10mm spacer for the rear, netting your offset on an 11" wheel to +40mm. I personally run a 19x11.0 +40mm wheel with a 7m spacer, netting my offset to +33mm with no issues at all on a 315/25/19 tire and unrolled fender. The 10mm spacer on that wheel would give you plenty of safety margin, but you could run 15mm spacer without issue as well.
Good luck and I hope this information helps you out sir.
Contact me if you have any questions!
Chris.
wheels offsets TR recommends are whack !! my friend here has 19" LMs that may be for sale. They are very rare and are aggressive at et 30
#TeamAIM
#TeamAIM
If he does decide to sell, would you please have him contact me? - I'd be interested.
Chris.
yeah fittment is nicey nice. pm me if you want and ill see what i can do. i know its pricey because of how rare the fittment is.
#TeamAIM
#TeamAIM
i run 45 front that looks weak and 35 rear with a huge 26.5" tall 305 dragradial and it fits just fine.
#TeamAIM
#TeamAIM
its close. 30 is fully flush
#TeamAIM
#TeamAIM
Why don't you simply opt for a custom solution? We talked about the FMS-01 before, a simple, yet elegant solution, can be obtained with or without hardware exposed, flat or step lip, numerous color finishes, sizes, custom fitments, the works.
away
04-27-2016 03:53 AM
johnnyg996
09-30-2015 11:19 PM
