Eddie Bello to race UR TT SL at the Texas Invitational.
#61
Vp c85 is a way for vp to rape people for money on e85! I'm pretty sure that with regular e85 you will reach the max timing you can apply before cylander pressure is your enemy not detanation. Did tests before on e85 vs vp import. I believe Awd mike can confirm doing tests also and made more power on e85 than any of the race fuels. You would be better off running e98 at 300$ shipped for a 55gallon drum.
#62
News to me.
#63
yup...
here is the Rocket Brand E85/112 mix. Green Barrel - i heard this one is serious !
http://www.rockettbrand.com/productspecs/specs.html
VP C85 spec sheet
http://www.vpracingfuels.com/C85-specsheet
VP C85 spec sheet
#TeamAIM
#TeamAIM
#64
best bang for the buck 10 gallons E85 to 1 gallons C16 i would never run E85 by itself. i know people running it on RB26 40psi timing retarded have no problems others running it on an EVO blow up all the time. yes you have E98 and better what i'm talking about everyday use and i trust this mix i use to use it. 1000hp works great.
#65
yup...
VP C85 spec sheet
VP C85 spec sheet
The C85 is only 90 motor octane so i would think you need to mix a little, i may be wrong.
#67
Eddie, good luck, stay safe and thanks for representing the P-brand so well.
Also, good info on E85 in this thread.
Off Topic: One question on E85. If you are tuned just for E85, and you add C16 or unleaded equivalent(VP110 or so), is that better(safer) than just running E85?
#68
safer absolutely it will run a tad richer nothing to worry about, the only drawback is the lead takes away some O2 sensor life. not as bad as running straight C16 fuel try it, won't hurt you can run more boost, ignition timing
#69
Thanks for the info, makes lots of sense.
#70
#71
you're right but the EVO in florida making clothes to 980hp we're breaking. they all running E98 now making 1000 to 1100hp and not breaking. because of the timing i run i can use E85 I would have to detune my car and lose 300hp to make it work. I run it time to time to putt around town
#72
#73
#TeamAIM
#TeamAIM
#74
I'm not trying to get into a Debate about E85 a race in FL I had a guy in a 996 come up to me ask me what type of fuel am i'm running i told him E85 mix, he said i running E85 my car is knocking can't turn up the boost i always get the gas from the same station. i told him E85 can be E70 E68 you never know what you're buying unless you buy a $500.ethanol meter and then what reprogram the car at the track. i told him put some race gas in the tank it's fixed it. yabba dabba doo LOL
#75
15$tester and works great. over 900+hp on 4cyl 2.0l single t3 turbo. Engine was built in 2008 and I sold the long lock do to building a 12:5.1 aluminum long rod especially for e85. But that engine still today is breathing in another evo tuned on e85 making 700hp.
http://www.quickfueltechnology.com/s...test-tube.html
