How to drain your tank and fill with race gas.
Some of us run race gas for high boost at the track. But when your tank has pump gas in it when you get to the track, how do you drain the gas? You can't siphon it. You can try to drive it until close to empty, but you may run out of gas on the road (happened to me many times). So I added a quick drain.
We placed a valve/fitting on the fuel line. Attached another valve to the end of some tubing.
Next, I replace the fuel relay with an on/off switch. When I turn the key to "on" and flip the switch to "on", the fuel drains quickly. Once the full is drained, I replace the relay and fill with Race gas. Rinse and repeat.
Or you can use the fuel return line located ontop of the fuel tank. If you are really trick you will get a stock fitting that plugs right into the factory connector for cars with stock return lines; you connect that to a hose you will use to fill your cans...
Or for you tricked out fuel system guys you put in a quick disconnect coupler that plugs into return line. Then you have your drain hose you conect to that coupler.
Then all you have to do is start the car and let its normal operations do the job for you. No extra plumbing or wiring.
Cool mod and good ideas here for other ways to do it!
Personally I just find it easiest to run the tank down and fill up with the good stuff when I get to the track. Sure, there's a bit of the of the old stuff in there, but it's pretty easy to end up with 1/8-1/4 of a tank by the time you get to the track if you plan ahead a few days. Of course for me I'm almost 100 miles away from the track so I've got a lot of miles to burn off gas before I get there, so as long as I have a 1/2 tank or less when I leave in the morning, I can always get to the track with less than a 1/4 and usually closer to 1/8.
Personally I just find it easiest to run the tank down and fill up with the good stuff when I get to the track. Sure, there's a bit of the of the old stuff in there, but it's pretty easy to end up with 1/8-1/4 of a tank by the time you get to the track if you plan ahead a few days. Of course for me I'm 90 miles away from the track so I've got a lot of miles to burn off gas before I get there, so as long as I have a 1/2 tank or less when I leave in the morning, I can always get to the track with less than a 1/4 and usually closer to 1/8.
04-28-2022 12:38 AM
turbotuner20v
09-11-2015 12:02 PM
