Upgraded at EPL!!!
Old 08-15-2012, 11:33 AM
nomadmai's Avatar
nomadmai is infamous around these parts
Originally Posted by MX RACER
Hey I saw your car when I was picking mine up.. I did the same clutch and I am very happy with it.. I bring my car all the way from MD Tony and dave are the best!!!!
MX I really like the the clutch. I fear was the Slave it would the clutch to stiff to drive but it feels great.
And, EPL is great. Just walk in and leave FASTER .
Old 08-15-2012, 11:39 AM
nomadmai's Avatar
Originally Posted by vntperformance
Did EPL have the inlet pipes in stock? Looks great!
They had to send the y-pipes out to be welded to fit the inlet pipes.
Old 08-16-2012, 04:13 PM
MX RACER's Avatar
MX RACER is infamous around these parts
I am from Annapolis, but live in southern MD now..
I like the feel of the gt2 clutch conversion much better.. I did the inlet pipes last year and I am happy with that decsion also..
Old 07-29-2022, 11:17 AM
K1shan's Avatar
K1shan is infamous around these parts
Originally Posted by nomadmai
Hey Fellow P-Car lovers. I would like to share with you'll my very satisfied EPL experience. My 2004 996 TT received the following upgrades:
-Stage 3 Cluchmasters clutch w/Duel mass flywheel
-GT2 Slave conversion
-USP 2.5" Aluminum Inlet Pipes
-Billet 16K/16G modified Turbos
-72Lb injectors
My journey began again with my trip to EPL to see what is was all about and ended up leaving with a flash. This time I went to talk to Tony about checking to see if My flash was erased after some recent electrical work. We re-installed the flash. And, during testing found a pressure leak. Replaced a broken clamp and I was good to go. But, not before talking Tony talking to me about improvements I could make. And, much like the first time I went to Talk with Tony and I left with a lighter wallet. But, a happier man.
The car drives great. very smooth almost linear accelleration some noticeable bump when the turbos hit. I still have to brake in the clutch. About 400 miles to go. And then I get the filnal tunnig done.
I would like to say Thank you to the EPL Team Tony, Dave and Rich
Here are some pics of the build to hold you over until the dyno sheets are in.
I currently own this car. Were the coolant lines pinned?
Old 07-29-2022, 08:39 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Should be able to visually check, some of the fittings are fairly
easy to check yourself. Check out the video below for the more accessible locations, to the left of the alternator may be the easiest?. At least this may give you some idea. Look for pins or welds.
crffl
10-15-2015 09:10 AM
dsa22
12-24-2009 01:27 PM
joe731
12-06-2009 07:59 PM
viprklr
05-09-2009 10:09 PM
996ttDMB
02-07-2008 08:15 AM
Quick Reply: Upgraded at EPL!!!
