creaking front suspension
I have the same creaking sound and I have PSS9 with Techart springs. Please post what fixes it. I'm in Phoenix and it's still 100+ here so I don't want to spend too much time in the garage.
Thanks,
Tim
Thanks,
Tim
sorry about the ot rant. that pop and creak remains for now, on the "list".
.. that i have snapped another three lug bolts again same right rear wheel on these f14's you once ran. sorry for the OT rant. i know i'm putting down a little power apexing, but man.. who snaps (3!) wheel lugs..other than me
thx for the info. was hoping to get under it for more inspection but it's dark out.. but found after my new c4s lip install ( all 30 seconds ).. that i have snapped another three lug bolts again same right rear wheel on these f14's you once ran. sorry for the OT rant. i know i'm putting down a little power apexing, but man.. who snaps (3!) wheel lugs..other than me
?? Snapping lugs. Where do you get the lugs from and did you really get the right taper angle and all that?
I never snapped a single one, in my life (knock on wood).
Also not on my CF10 I have now (exact same lug model/dimensions/brand). On racetrack and in canyon with very sticky tires and using all power.
I could imagine if they possibly are overtorqued, they could snap quite easily. Or if one lug comes a bit loose and you don't notice and keep driving, then retighten it much later, loose bolts are throwaway items, they get damaged. Not saying you did, just ideas.
sorry for the threadjack. hoping to get a look under the car again tomorrow.. while properly installing new lugs
the first were forgestar supplied. second set, not sure. but i'll be paying much closer attention this time around.
i had the same problem after having my pss9's installed, the installer had not re-installed the thrust washers, my new mechanic bought them and installed them, there is no noise at all now
the previous installer tried grease and some plastic part he had made but this didnt fix the problem, when i went to them and suggested they may not have installed the washers, they told me they had, i gave them 3 chances to fix the problem and nothing they did helped so i went to a new mechanic and he discovered immediately what the problem was...the washers were missing ! the owner of the previous company had told me he personaly saw them being installed ! after i threatened legal action the first mechanic finally wrote me check to cover the cost of the second mechanic, except the cost of the alignment as he didnt think that was necessary !
Buzz,
I'm pretty sure the OEM suspension does not use the thrust washer bearings. I added them with the PSS-9's years ago.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Just did lowering springs last week and I will say on my '01 that the bearings were ball bearings and they actually had split in half over time. Oddly enough I never had any noise until after I put the lowering springs on?? But if anyone needs them here's the link to order the part: http://www.pelicanparts.com/cgi-bin/...30%35%29%20%20
until then, i'm waiting on gearhead to figure this thing out for us.. and a torque wrench for my new lugs
i researched the problem and found a bunch of other people who once thrust washers were installed the creaking/twanging noise problem was solved
Agreed - it's the proper fix, IMO.
2022 Cayenne White
2022 Cayenne White
