Center caps for my BBS CH-R's
Was hoping someone could recommend a quality source for wheel caps, I'm told they will accept the stock wheel caps, so I assume they are the same size wheel caps that came on the turbo twists.
My CH-R's are finished in black, looks to be Satin Black. The BBS caps that came with the CH-R's are real cheap, over time, probably from heat cycling they become very loose and eventually fall out. The plastic clips are a horrible solution.
Can anyone recommend a solution in black, Porsche crest, turbo logo, or a higher quality BBS cap with metal clips ? Gloss black may look nice as the car is black, I suppose satin would be just fine also.
Much appreciated.
Much appreciated.
Wheel Enhancement has the best caps IMO. Suncoast is a good source, too. I sell the wheels and OEM caps, but I am not aware of BBS having any that have metal parts. If you want top of the line, Ralph Boothe caps are the best. Good luck.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
Lot's of chrome, but really nothing in black for 60mm
http://www.wheelenhancement.com/index.php?t=AccCaps
Maybe they have others that aren't on the site ??
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
