Took the power plunge: Alpha 76's
#61
Greg U gotta get on a dyno my friend !
#TeamAIM
#TeamAIM
#66
Looking forward to your install and impressions. I am in the same boat as you and will be upgrading to 3076's as well. Just spoke to Mark @ 911Tuning today to get the parts coming for the build.
Enjoy sir!
Chris.
Enjoy sir!
Chris.
#68
im guessing depends on who is tuneing your car..I have ran 24 psi on a mainline dyno on ms109 fuel and have made 718awhp..I run alpha 3076, bigger intercoolers,stock injectors, PROTOMOTIVE tune, stock y pipe, stock tb, stock motor..
Some tuners tune different..so pick your tuner wisely when upgrading your turbos..
#69
you can run 1.4 bar on 100 or 104... 104 sunoco is good...
2001 996TT 3.6L and stock ECU
#70
#71
#73
I dont think you would be happy upgrading your turbos from 18G to a billet 20. You will gain some power I am sure, but I don't think enough for you. I think if your going to pull out your turbos you should go with some big boys and be done.
#74
HI, Thanks for your input..You might just be right...
