Took the power plunge: Alpha 76's
Old 10-03-2012 | 12:51 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
Just pulled the trigger on a set of Alpha 3076's, brand new in box, am already extremely excited to get them, install then, have tony tune them.
What did I just sign myself up for?
cheers
Old 10-03-2012 | 01:06 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Cool, what are you running now?
Old 10-03-2012 | 01:19 PM
running AMS billet 16s with every supporting mod under the sun (except my intake, y pipe and TB are currently still stock)
Old 10-03-2012 | 01:30 PM
SamboTT@ByDesign's Avatar
Slippery slope! Enjoy!
Old 10-03-2012 | 02:31 PM
johnspeed's Avatar
Enjoy your new rocket..
Did you ever think about going to the 3071 before you decided on those big boys?
Old 10-03-2012 | 03:06 PM
nope, was told go big or go home. As it is my current setup was MORE than enough (yes, shocking). I figured if I am going to make the change, might as well do it in as drastic a form as possible.
Old 10-03-2012 | 03:31 PM
Tial will tell you the spool diff on the 76 vs the 71 is negligible with a good tune. Not enough to worry about. You'll get a smoother delivery (on the rods) too.
"MORE than enough"
Old 10-03-2012 | 03:38 PM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
cheers
a lot of freaking power and tq
Old 10-03-2012 | 03:41 PM
am looking forward to it, and i thought my billet equipped car was fast...o wait, it is..
Old 10-03-2012 | 04:03 PM
Have any current dyno's or figures?
Old 10-03-2012 | 04:19 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
More power and it will keep pulling and pulling and pulling and repeat until you hit the brakes
Old 10-03-2012 | 10:00 PM
I would change out the TB, Y pipe and plenum while you're in there. You're going to make a ton more power. You'll Max your motor with those turbos.
Old 10-04-2012 | 05:26 AM
32krazy!'s Avatar
what supporting mods are needed with these turbos? i already have 75mm t/b and plenum, headers, 3" exhaust, gt2 i/c. bigger injectors? stronger internals?
looking down the road for the next phase of the car.
Old 10-04-2012 | 05:34 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
What amount of power do you expect with these turbos?
Will they be on a stock internal motor?
Have you seen any dyno #'s using these on a stock motor?
Old 10-04-2012 | 07:32 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
subscribed.
