Limp mode problem...
throttle body + sensor
Throttle possition sensor circuit "a + b" is what my scanner told me. Mine does the same thing.. I drive and hit a max of 0.2 boost. I'm flashed and usually hit 1.3 bar after 2500rpms. Car struggles and doesn't pass 4500rpms very sluggish! I do resets wit my scanner and it remains sluggish , resets the codes and they appear again after a couple minutes driving.
People all been telling me its the throttle body and my pedal positioning sensor..
Does youir problem sound like mine? Let me know
philly
let me get this straight . as you were cruising the car just last power and wouldnt rev , even when u pressed the accelarator .
so when you pulled over as the car idled it was irratic, then when you shut it off and restarted it was good to go ?
cuase same exact thing happened to me this morning .... and i was in the fast lane cruising with a tractor trailor next to me and it just cut off (hitting the gas but wasnt accelerating, it was just slowing down), traffic was crazy couldnt get over to the shoulder to my left, and everone was riding my a$$ ...
finally pulled over , car was idling erratic shut it off then restarted and was fine....
i have a blow though with a ford MAF....
I put some dielectric grease on my connection... (connector for the MAF) It hasnt done it since.
I'll keep you posted... and you keep me posted!!
absolutely .
I dont think its the maf... that maf either works or not... if the harness is loose that will cause odd issues... what about the TB acting up? or the sensor... he had some CEl go on.. check the codes...
2001 996TT 3.6L and stock ECU
Gas Accelerator Pedal Sensor 0280752010 could be the reason but in this case you find a exact code with diagnostic tool.....two failures are possible at the actuator ore at the TB Sensor ....if one failes the TB dont open and goes in a limp mode phase at the TB System...only 0,2 bar and drive like a 40hp car....
GT3/GT2/GT Vendor Classifieds
10-13-2015 03:07 PM
