No back up lights - reverse light switch?
Old 10-16-2012 | 07:55 AM
gottspd's Avatar
gottspd has a spectacular aura aboutgottspd has a spectacular aura about
Vehicle: '01 TT
Hi.
I installed a backup camera in my car this weekend and in the process discovered that my backup lights don't work. It seemed like it would be an easy fix until I realized that the switch for the N/A 996's is different than the turbo cars. I've read that that the switch is tied into some part near the gear selector, but I'm not sure what it is I'm looking for. I've also heard that there's a relay that could be the culprit. The issue isn't the B5 fuse (sadly). Can you help me get started on tracking down the issue?
By the way, the camera gets a thumbs up! While the picture clarity isn't quite as good as a factory camera, it works well enough for me. I have an Alpine IWA-D310 headunit.
Old 10-16-2012 | 09:10 AM
ECS Tuning - Porsche's Avatar
It sounds like its the backup light switch. It's located on the transmission tail shaft. Its the same part as on the regular 996.
Old 10-16-2012 | 12:44 PM
gottspd's Avatar
Hmmm.. Pelican said it wasn't, alldata doesn't show it and the little bit I have seen online also seems to suggest otherwise. Is there anything you can point me to that would show my indie that it's the right part? He's been looking at alldata and it doesn't show the part on the trans... Please know that I'm not trying to be a d!ck. Simply trying to sort out conflicting info. I am hopeful that you are the one who is correct!!
Old 10-23-2012 | 10:03 AM
gottspd's Avatar
By way of an update, it was the switch. A liberal cleaning with electrical contact cleaner and it works like a charm!!! Not only that, but now my mirrors tilt down when in reverse (as they are tied in to the same circuit).
Woohoo!! Now, if only I could get all of these darned check engine light issues resolved.
Old 10-23-2012 | 10:06 AM
That's great news, glad you got it figured out. What issue's are you having with the check engine lights ?
Old 10-23-2012 | 12:29 PM
gottspd's Avatar
We found one damaged vac. line and fixed that, but I've gotten a handful of additional codes since then. The car has a new MAF and TB, so it's likely just additional vac. leaks, but I haven't looked carefully to find them and I'm not terribly comfortable pulling stuff off the engine to look.
Old 10-23-2012 | 01:08 PM
gottspd's Avatar
So far I've gotten a P1072 and 1109. The 1109 came when the turbos were boosting and 1072 came while I was sitting at a traffic light.
Old 10-23-2012 | 02:13 PM
Those faults normally indicate a boost leak.
Old 10-23-2012 | 06:07 PM
gottspd's Avatar
Any thoughts on common places to look?
Old 10-24-2012 | 12:40 PM
Boost leaks are usually found at the intercooler hose connections. The best way to check is to buy or build a boost leak checker and pressurize the turbo inlet on each side with compressed air. If there is a leak, you'll be able to hear it, and trace where it's coming from.
04-28-2022 12:38 AM
DetomasoGTS74
11-11-2015 09:01 AM
The_Ruski_Driver
10-25-2015 08:40 PM
ECS Tuning - BMW
08-21-2015 02:00 PM
ECS Tuning - BMW
08-21-2015 01:47 PM
Quick Reply: No back up lights - reverse light switch?
