The little 3.6 that could!
5th in line after lunch break, didn't get to tech until this morning. Then Hennessey blew up motor in Ford GT which shut track down for a bit. I need to do a qualifying pass at under 215 and then we can go all out. Todd told me to run 50 psi on my low pass - is that right?
Thanks for the interest and I'll update as soon as I have something to tell.
~Mike
~Mike
First pass aborted after 1/4 marker and coasted thru 1/2 at 159, car threw a light, I believe it was my fault.
Will update later
Will update later
OK thanks & good luck. Waiting for a good run.
Thanks for all the comments, I went for 4th gear twice, but the car was strong enough to still pull the speed. 161 at the 1/2 (slow), improve that tomorrow and apply some boost - we should do ok.
