Turbo Front Air Ducts For Radiators
Hello,
I am the proud owner of a 2002 C2 I picked up from another member on here. The front bumper and lip spoiler was swapped over from a Turbo model, and the duct work doesn't quite jive in the front of the car. I would estimate that half the amount of air is being directed toward the radiators....
Could someone be so kind as to provide some part numbers and possibly some sources to get a hold of these ducts?
Thanks!
Thanks!
Hi, welcome to Porsche ownership. Try this site: http://sonnenporscheoemparts.com/par...05&searchText=
select your vehicle and then look up the parts via the diagrams. Not sure if there is an exact match. You might try something like a 40th anniversary 911 which had the turbo front. The C4S also has the turbo front. Good luck
Welcome to the forum and congrats on the new purchase !! We need photos to make it official though So do you have the Turbo ducts that aren't matching up to the C2 radiator ? Or you having a problem with the C2 ducts that aren't matching up to your Turbo bumper ?
I currently have a turbo bumper on a C2. Once I got the car in the air I realized that only half of the air entering the front vents was being diverted to the radiators. Simply replacing that plastic insert/diverter on both sides will correct my issue.
I have a set of all the front ducts from an 01 Turbo if you are interested. Left, right and center. Also have a center radiator but you probably don't have a need for that. PM me if you are interested in the ducts though.
ECS Tuning - VW
08-19-2015 08:58 AM
