Axle nut torque spec?
Old 11-22-2012 | 04:41 PM
Eggman's Avatar
Eggman is infamous around these parts
Doing my coil overs today and need the axle nut torque spec for a AWD TT. Looked around but didn't see it posted. Thanks. Gobble gobble.
Old 11-22-2012 | 05:32 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I heard about 340 ft lbs on the front nut. Most all your weight on a 2' breaker bar.
Old 11-22-2012 | 08:17 PM
pwdrhound's Avatar
Exactly what Nick says, 340 ft/lbs. I weight 170 lbs and use a 2 foot breaker bar. I stand on the end of it and voila, just applied 340 ft/lbs.
Old 11-22-2012 | 08:24 PM
32krazy!'s Avatar
how does everyone keep the hub from turning when torqing the nut?
Old 11-22-2012 | 08:35 PM
pwdrhound's Avatar
Take off the wheel center cap and loosen the center nut with the car still on the ground. If you already have it jacked up with wheels off then have someone stand on the brakes.
Old 11-22-2012 | 08:43 PM
32krazy!'s Avatar
thanx i can lower the car on the lift to get the nut tight.
Old 11-23-2012 | 09:07 PM
rangerdick's Avatar
rangerdick has a spectacular aura aboutrangerdick has a spectacular aura aboutrangerdick has a spectacular aura about
Plus 2 for 340 lbs. Page 251-252 in the repair manual gives all the torque specs for the axle and running gear.
WheelB
991 Turbo Vendor Classifieds
07-23-2018 10:37 PM
zuman
09-03-2015 09:27 AM
manfred@loma_wheels
09-02-2015 12:22 PM
