Sunroof Gremlins
Sunroof Gremlins
I have a weird one:
Went to open the sunroof - to the slide back position - single click at the back of the button but nothing happened. Clicked the middle of the button and sunroof opened into tilt up position ok. Closed with forward of the button. Then I could open to slide back position but only if I kept holding the back of the button. I also couldn't close with just a press of the button but had to hold the front of the button. Switched the ignition off and back on and then it all worked perfectly. Back to normal, I thought computer gremlin. Used the car 3 hours later and same thing...
Any ideas?
Any ideas?
It seems more electrical to me... Tracks are more mechanical. Also if I hold the switch sunroof runs back and forth fine.
Could be your sunroof controller going out on you. You can try to reset it (I can't remember the sequence, but a quick search of the forums should work) -- but that only worked for a day or so, and then it started acting up on me again. Ultimately, I had to get the control module replaced.
Just giving some input..
I tried to reset as per web instruction - in my case nothing happens. "Open the sunroof to tilt position, then release the button, then press the switch again in the middle and hold for 10 seconds, the sunroof will then go into self-adjusting sequence." In my case zero going into the sequence... do you remember where the module is located (where the button is?) & the control module cost?
Terminator, sorry for slight OT, did you get your 2nd gear pop put fixed? Did detent do the trick?
Yes fingers x-ed. Had it fitted, went to the local track and really abused 2nd gear for a while up/down the rpm range with max acceleration and abrupt lift offs. I couldn't pop-out the gear. It also seems my gearstick slots into gear a bit better. And when I lift off abruptly it seems car jolts tighter. So far, so good, I recommend the fix.
Damn forgot to close the thread;
gl w it.
I bet it is the controller, knowing my luck!
Good luck.
I have found most reset instructions I have found do nothing in my 997.2. I found another post somewhere that worked for my car:
1 - close the sliding roof
2 - hold the forward/close button (referred to as Rocker Switch B in the manual) for several seconds / don't release it
3 - the sliding roof will go through an opening / closing / sliding sequence that ends with it closed.
jaehoppa
10-22-2015 09:17 PM
