changed my throttle today, and now getting throttle/pedal sensor errors??
still no dice! disconnected battery, waited about 15 min, reconnected, ignition on for 1 min without touching throttle, off for 10 sec... still same p1235 and p0121 code after .2 miles of driving...hmmm.... whats next!???
Well, either throw Porsche diagnostics computer time at the symptom or throw expensive parts at the symptom.
These are very modern cars with sophisticated control systems, including the e-Gas which because it is a safety critical system is a rather complex piece of hardware and software engineering.
One just doesn't tap it with a hammer and fix it.
The error codes you can read out, along with the ones the tech can almost certainly read out should point the tech at the source of the problem.
PelicanParts.com
08-26-2015 04:25 PM
PelicanParts.com
08-26-2015 04:24 PM
