Door speaker removal
You will need to remove the door panel. There is a hidden screw behind the airbag tag. You will need to gently pull that out and pull the mirror and door pocket. Remove all of the screws at that point and pop the panel up. Once up you can then access the speaker. If you need a diagram email me and I can PDF the cutaway for you.
