Greddy Profec B problems
Old 12-17-2012 | 03:08 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Just noticed that my Greddy Profec B spec 2 doesn't appear to be working. The unit comes on and I can go through the different settings. But, the display unit only shows "0.00" when I start it up and "-.01" when I go WOT and ease off. I know the unit isn't working because the stock pressure readout in the dash shows a solid .70-.80 bar at WOT. So this tells me something is wrong with the Greddy. The solenoid connections are fine and there are no boost leaks. Any ideas, i.e. bad solenoid? Thanks.
Old 12-17-2012 | 03:30 PM
Tim941NYC's Avatar
I never used the greddy unit but it does not sound like a solenoid problem but more like sensor/sensor line problem. The unit should read the boost psi even if the solenoid is not working.
Old 12-17-2012 | 04:32 PM
Fire's Avatar
Fire is just really niceFire is just really niceFire is just really niceFire is just really niceFire is just really nice
find the break in the hose from the rear of the unit to the engine that reads vac for the display
Old 12-17-2012 | 05:42 PM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
Bad headunit was the case for another members car I fixed... I tried replacing the solenoid with a new one and that did nothing...
Old 12-17-2012 | 05:48 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Just get a new one. I haven't had problems with the ones I've owned but others have gone through a few of them.
Old 12-17-2012 | 07:21 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Well am sorry for you !
But if you want my advise it will be much better / easier to swap the greddy with HKS evc6 boost controller much easier and you can fully controll the boost .. !
Regards
Old 12-19-2012 | 09:29 AM
Going to look to see if there is a break in the line that reads the vac as suggested by Fire. I hope that's all that is causing this problem. Otherwise, I HAVE to buy the new Greddy Profec OLED!
Old 12-19-2012 | 09:59 AM
head units go bad when there is a short in the wire harness... head unit is bad...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 12-19-2012 | 10:24 AM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I had a similar problem with mine, it was deafulting to the wastegate pressure (1bar) regardless of what I had selected, thought it was a bad headunit, ended up being a small 2-3" hose that was cut, this hose is located on just on the right of the centerline above the secondary air pump, you can clearly see it when opening the engine cover and look just underneath the overhang on the right.
I also had one of the in tank fuel pumps go bad but thats another story....
YJosephTT
03-28-2016 02:31 PM
cockneymike
10-22-2015 06:00 PM
Fadi
10-05-2015 12:14 AM
vogz
09-19-2015 01:02 PM
nal991
09-11-2015 09:05 AM
Quick Reply: Greddy Profec B problems
