Getting started on my 18G conversion, anything I'll need?
Going to install my 18g turbos as well as my new clutch in the next week or so. I'm going to take my time as I don't really drive the car in the winter much anyways. Also going to do the GT2 slave setup and some other maintenance like welding or pinning the fittings and maybe a new water pump. I am going to pull the engine for this. I'm going to build my own exhaust for this setup also. Here is my parts list, let me know if I am missing anything or if there are any surprises. Any advice is appreciated.
K24/18g's
Turbo gasket set
Spec Stage 2+ clutch and pressure plate
Siemens 60lb injectors and spacers
Spark plugs, not sure which are best?
Durametric (will hire a tuner once finished)
Still need to buy:
Diverter valves
Various GT2 slave setup parts
Stuff needed to disable clutch boost pump parts?
Various parts for exhaust setup (planning on using a magnaflow tru X muffler which worked well for a member here.
K24/18g's
Turbo gasket set
Still need to buy:
Diverter valves
You may want to consider adding an intake and intercoolers/ hoses to the list
I did a similar upgrade last winter. If you are doing the work yourself for the first time you may want to read thought this post for some ideas
https://www.6speedonline.com/forums/...bolt-mods.html
Good luck
Good luck
i set mine up for future k24/18g upgrade.
contact john @ speedtech
i purchased the oem modded intake distributor and 70mm hard lines, y pipe and silicone hoses, 72 lb injectors, 3.8 fpr, ams 1 bar wastegates, epl flash. im building a set 4.5" i/c from the 02turbo996 build thread.
if you have the motor out do it then!!!
careful what you wish for!! i ordered mine for speedtech and im here to tell everyone with the motor in the car this is a major BIATCH!!! it took me about 2 days to finally get this thing out of the car. i will be reinstalling the new parts this weekend and pray it goes back in easier than it came out.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Atleast you are going to get it over with all at one time. ..You will save time and money doing it this way..
Yea, Steve has 4.5" intercoolers with 2.5" end tanks, too!
2022 Cayenne White
2022 Cayenne White
he wanted to.actually john and i discussed it and feel the lag on the 20's may not work for me. seems better spool on the 18's but i declined for now.( hence the interest in yours!) want to see if i can squeeze 600 rwhp or get close before swapping the turbos. hopefully the wallet will have cooled down by then!
Good Luck,,hope you can..
dont know if i can to be honest. i have 490 rwhp and 502 ft/bs torque so im optimistic. if i can get close then ill upgrade the turbos next yr.
IF I was to guess with all those mods and you would be 1.2 bars to 1.3 bars(pump gas],I would think about 540 on rear wheel dyno..
Hope I am wrong for you sake..lol.
Again, Good Luck..
