Trying to collect parts for GT2 slave conversion, PITA
Trying to build my own parts kit so I don't have to pay 1000 for the evoms one. Looking on Pelican Parts and I can't find everything I need. They don't seem to have the GT2 master cyl or assist spring but they do have the GT2 slave and brake fluid cap. Planning on making my own hose and getting my own hardware for this. Where can I find this stuff?
These are the parts numbers I have from this thread https://www.6speedonline.com/forums/...=GT2+slave+diy
GT2 slave: 996 116 237 90
GT2 master: 996 243 71 06
GT2 assist spring: 996 423 081 13
Brake fluid cap: 996 355 119 01
Don't bother with the assist spring,, most remove it anyway..
I think the hydraulic line is: 996 423 377 90. Some say it is kind of short, so making one might make it easier to install. $126.
http://www.rmeuropean.com/search.asp...rd=99642337790
this thread may be of help also. same guy built the 4.5" and posted the plans. he really knows his stuff!
https://www.6speedonline.com/forums/...onversion.html
GT2 Slave
GT2 Master
GT2 Assist spring (you definitely want this, trust me)
Brake fluid cap
GT2 Hose
GT2 Clutch fork
GT2/Tip PS reservoir (optional, you can just plug the lid)
GT2 PS pump (optional, just remove the coupler from the turbo pump)
Drill and tap the transmission case, remove all existing clutch hydraulic likes, and you have a GT2 system just like done at the factory...
Any dealer will be able to order the parts for you. Just tell them you need the parts listed below for a 02-04 GT2. I just looked in PET and bought all the factory GT2 parts except the PS pump. I just had the coupler removed from the turbo PS pump. It was a no brainer. You need the following parts:
GT2 Slave
GT2 Master
Brake fluid cap
GT2 Hose
GT2 Clutch fork
GT2 Slave
GT2 Master
Brake fluid cap
GT2 Hose
GT2 Clutch fork
Stuff that will come in very handy for me later.
GT2 Slave
GT2 Master
Brake fluid cap
GT2 Hose
GT2 Clutch fork
GT2 Slave
GT2 Master
Brake fluid cap
GT2 Hose
GT2 Clutch fork
i bought everything from pelican
#TeamAIM
#TeamAIM
like the op said i tried both sites and couldnt all the needed parts. was just wondering what the total would be.
