Can't Clear codes; can't start car
Last week while driving my car just totally stopped running.
I bought a Durametric and have pulled codes from the car. But I can't clear them. When I hit clear codes they don't go away.
Here's what the codes are:
5522
DME: CAN message missing
ABS/PSM 5.7Module Identification
9110
DME control unit
Instrument Cluster K21Module Identification
Automatic Air Conditioning H01
Current Fault Codes
35:
Instrument cluster signal fault (see instr. cluster fault mem.)
I disconnected battery and let sit for 30 minutes and the car ran for about 3 minutes tonight. Then I had an ABS failure light come on and then this Failure Indicator Light.
I'm very frustrated.
5522
9110
DME control unit
Current Fault Codes
35:
First of all, chack your battery voltage and recharge it. The combination you have there is a heavy one, almost seems like total failure of CANbus system...but low bettery can explain it. The next ones are faulty wiring and damaged Motronic...
What was done on the car lately? Was there any job done in the dash area. Radio installation, etc. There seems to be lack of communications with the instrument cluster. Also, are you using the latest Durametric software 6.3.1.5? If you are using 6 download the latest version of 5.1.3 and try again. I had problems with version 6 and sometimes I revert back to 5.
JP, good advice on version 6. I don't know about version 5, but the Durametric doesn't seem to be working well. I will do what you said and try again.
No work done on dash or anywhere in the care lately. Only thing I did was replace light bulbs in the dome light last month. Car drove fine.
The first two fault are related to signal from the DME. Any water infiltration? I think you will have to look at the DME for a loose connector. It is located behind the rear seats....
No Performance has been great. This did happen as I was driving 'briskly' on a mountain road. Car was being pushed pretty hard. But performance has not been abnormal or odd at all lately.
Took out my Optima red top and took it to get tested. They show that it is bad and are going to work on rebuilding it?? (Never heard of that before, but I trust this guy).
So I will report back tomorrow once I get the fresh battery in the car.
Sounds like a good news...Peter was right!
Jim
