Whistling Sound coming off boost
Was doing a logged run .... and I heard a very noticeable whistle sound coming from the engine bay when I came off boost.
Opened up the engine bay and noticed that this hose has a play of around 2-3" ...
Could it be also the DV's?
Also attached the actual log itself ...
Thoughts?
Thoughts?
sorry, beyond the limit of my experience. if it's like a "honking" it';s most likely the dv going bad. if it is a WHISTLING that can be eliminated by depressing the clutch, then it;s the PS res valve whistling 996t oddity # 39. most of us have switched out the res by now or previous owners may have since it was so common. there is a TSB on that one if you search, you'll find it in here.
good luck w it.
good luck w it.
those are the conditions present when it ( ps res whistling ) happens. hot engine after spirited driving. it's a valve inside the res itself that resonates/vibrates unwittingly and annoyingly. read up on the power steering pump reservoir issue.. and see if if it sounds like it mirrors your issue. best i can do.
Mine was making a whistling noise coming off of boost as well. Also noticed it would over boost to 1.5 bar (I have an EPL tune, set to I believe 1.2 bar). Read up that if a hose pops off the N75 valve overboosting can happen.
Well I looked and no hoses popped off, but I found a split in the Y-pipe that the DV's connect to. This explained the whistle, and the over boosting because the N75 valve feeds off of this Y pipe.
plastic hose in your hand is not the cause of your noise.
#TeamAIM
#TeamAIM
DVs are easy enough to check and are known to make noise when they go bad. N75 wouldnt really make noise. Check DVs and the F-hose. do yu have stock DVs? if so i would just swap them anyway, its much easier if u lower the motor, very tight space. also pneumatic pliers make this job much much easier.
#TeamAIM
#TeamAIM
I'm having the exact problem. Noise only off throttle after boost. Recent work done: turbos, 1 bar WGs, coolant tank, GT2 slave conversion & new P/S pump. Pressure tested system at 25 psi no leaks.
04-28-2022 12:38 AM
