Intake pipes worth while on 550whp car?
depends on other mods too. i gained nothing from inlet pipes at 500whp level. i think 550 is where the gains really start to show, you definitely want inlet pipes for any hybrid turbo to perform best.
#TeamAIM
#TeamAIM
Found out for myself, similar results ,didnt gain anything when I was at around 525 HP to rear wheels..
Its the most overlooked upgrade in my opinion...
2001 996TT 3.6L and stock ECU
They did alot of testing with their 16 car back in the day..
So can I just cut off the driver side pipe and weld in a fitting? Just use soft pipes of my own design then? 1,000 is a bit much. It looks like I can build them for 1/4 of that.
mine looks like the used a 2.5" piece of tubing and squeezed it to fit the plenum then welded it up
the hard piping I dont recommend... they in most cases rub and seen plenty of products that do the same- all due to improper installation....
62011113841pm.jpg/][/URL]
Marski,
I see on your site that you sell a hard pipe set and a bendable tubing inlet set.
How hard is it to install the bendable tubing inlet set with the engine still in the car?
If it can be done is how long does one need to do the install?
Bobby Ali
ba
Bobby Ali
ba
we do it with motor in car... lowered
the hard part is taking out the OEM piping...we cut it out...
then its easy...
total job with a lift: 4 hours...
then its easy...
We ran 911tuning inlet pipes on 3 cars in my area !
With big great success !! Billet K16 , K24/18G and a3076 !
All the setups , the turbos became very very fast in spool !
You should do it bro
Regards
Yousef
Regards
Yousef
IMO, if you are going to do this upgrade, do it completely and do it right - it is not worth cutting corners. Our plenum/pipe combination eliminates all factory bottlenecks and keeps a smooth, uniform high flow tube for the entire length of the intake track. Our high density plastic piping is virtually indestructable for long term reliabilty - it has lasted 100,000 miles of spirited driving on our test car with no signs of wear or wearing through at any point, which speaks volumes for this design. We also offer a modified OEM plenum design with the hard piping and it is less expensive, but I do not recommend it when tackling the job of upgrading your plenum. IMO, if you are going to increase the flow of the intake plenum, do it fully and be done with this area...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
