Is this normal tire wear for 996TT?
Old 03-17-2013, 06:24 PM
johnspeed's Avatar
My tires had a similar wear pattern..
I put on new tires and then I brought my car to the Porsche dealer for an alignment..
I was on the other end of the specs,so they realigned to the other end within the specs..
No problems with tire wear like that anymore..
Old 03-17-2013, 07:00 PM
'02996ttx50's Avatar
mine ( ps'2's ) wear rears at 6k miles also. with x73 alignment/lowered. no gettin' around it. 1.5-2 sets of rear tires are an annual expense.
Old 03-18-2013, 08:04 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Yeah but you are slower through corners. :-)
Old 03-18-2013, 08:36 AM
johnspeed's Avatar
This maybe true but I am not a track road racer, so I am Ok with that..
Old 03-18-2013, 10:41 AM
porka's Avatar
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
Originally Posted by Aerodude
I don't think I need these yet -- but I assume I'll need these if (when) I upgrade the suspension and lower the car.
The MPS2s are inside/outside rather than directional. Also, I'm sure you'd have to flip them well before showing cord (unless you can find a shop that would remount tires showing cord ).
you asked a question and i gave you the fix.. if you are worried about tire wear dog bones are the only way to adjust camber unless you get adjustable control arms.. which cost in excess of $1800
Old 03-18-2013, 12:27 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Hey Eugene, I remember you were looking for a new set of tires a little while back; are these the new set?
Old 03-18-2013, 07:48 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Nope. These are the tires that I got shortly after I bought the car. I have a nearly new set of MPS2s on my GT3-style wheels that I got from the PCA Group Buy last year.
Old 03-18-2013, 07:51 PM
Aerodude's Avatar
Thanks for the tip on the fix. I had thought that I wouldn't hit the limits of adjustment unless the car is lowered.
Old 03-19-2013, 06:12 AM
MY996TT's Avatar
Wow, you sure go thru them fast.
Old 03-19-2013, 07:10 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
The same thing happened on my Supra when I went single turbo (going from the stock 325lb.ft. of torque to 600lb.ft. of torque).
The cure was to add a little more toe in. In theory, the rear was squating so much more, it was causing excessive toe out under acceleration.
Since the suspension layout and geometry are different on the 911 versus the Supra, I don't know if this will change anything. Typically wear on the extreme edge of a tire is toe related.
Just my 2 cents,
Steve
Vicelord
Ferrari
17
01-26-2017 12:50 AM
PAULUNM
14
05-27-2016 06:54 AM
Nikg
09-21-2015 10:32 PM
horsepowerfarm
09-10-2015 06:09 PM
docboy
09-06-2015 06:57 AM
Quick Reply: Is this normal tire wear for 996TT?
