RWD Conversion - Front CV Mod
Both. Save about 70lbs with a full conversion, and you get that GT2 feeling...
My car felt much faster with the RWD conversion, and quite frankly was useless as an AWD vehicle. Some just drop the front axles, which is kind of useless. The right way is to remove axles and front differential.
The good thing here is that if you don't like it, you can always go back provided you save everything and don't destroy the axles.
I hear you. Quite honestly, I bought the 996 Turbo because it was AWD. After some seat time, I realized it was all hype. I dumped the AWD and went FULL RWD. Car was WAY more fun. I did a lot of additional weight loss mods to the tune of 250lbs, so it was very noticeable mod. It's really only about an hour job if you are handy with a wrench. Maybe a little longer if you don't have acces to a lift.
I'm excited to try it out. The AWD in these cars is terrible anyways, even with snow tires it wasn't anything to write home about in the winter.
With the engine being in the back, I don't forsee any traction issues either at the HP i'm at. The saved weight is just an plus.
I'd love to try out a car with this to see how it feels. My major concern that keeps me from being gung ho about trying it on mine is that the weight distribution is already far too biased to the rear for my liking so I'd rather not make it even more biased. On the other hand I love the idea of losing more weight.
Says the guy from SoCal.
The Gallardo AWD is light years better than the 996tt AWD. As soon as the 996tt dif takes crapper, it's dead weight anyway...I liked my car WAY better after the RWD conversion...many feel the same way...you can actually drive the car.
hehe.
I like the AWD in the rain. The extra stability is nice too w 640HP. Any understeer I used to have was fixed w/ a properly set up/aligned PSS9 setup and 235/245 front tires, but I get it to each their own.
Wrong. The GT2 stub axle will not fit the TT. Been there, done that.....
Because that wasn't an option the first few years they were made.
And If it a GT2 didn't cost so much more than a turbo, I would've bought one too.
When you remove the front diff you will end up with a one wheel drive car due to the fact that the 996TT has an open diff. To do the conversion to RWD properly you will need to get an LSD. An LSD is a fantastic addition to AWD as a matter of fact. It's a whole different car. It's amazing how many people get all wrapped up with adding power when an LSD is one of the best mods for putting power to the ground. I wonder why all GT2s and GT3s come with and LSD from the factory, hmmm......
