Stiffer Springs = Oversteer
Old 04-22-2013 | 04:58 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
Hmm.. it does not sound right....Drop links front and rear are good ? can you check engine mounts ? ..what tire pressures ?
  #32
Old 04-22-2013 | 06:26 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
What spring rates do you have? Which front sway bar?
Front and rear drop links are good. Engine and trans mounts are good.
R888s, 32-34 front hot and 34-36 rear hot.
Going to double check the spring rates on the front (confirmed the rears).
I wonder with the KW V3s if some how the gas pressure chambers (one to all of them) are not correct, or missing pressure altogether
  #33
Old 04-22-2013 | 06:52 PM
Hm
front sway bar: stock .... yea something sounds fishy....something sounds lose or bad alignment. I wish you were in norcal and i could take a look for you.
  #34
Old 04-22-2013 | 07:40 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
F1, where in the bay do you get your alignment done?
  #35
Old 04-22-2013 | 07:54 PM
TC Design.
http://www.tcdesignfab.com/
Let If you want your car to handle similar to mine. Let him know you want similar settings to Enrique's car. great great rotational ability.
  #36
Old 04-23-2013 | 09:54 AM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Assuming your tire circumferences are not a miss matching causing PSM to kick in at odd times, I'm betting a mismatch in spring rate ratios f to R causing a ride height issue making the rake angel unacceptable.
This has nothing to do with corner balancing. A sharp suspension tech may pick up on it comparing total front to total rear weights as compared to the total or a check on your caster angle. The difference in the latter may be too subtle though. Also your compression and rebound dampening may not be matched to your spring rates.
Logic tells me your front rates may be too stiff. Good luck!
  #37
Old 04-23-2013 | 10:34 AM
996TWINS's Avatar
Hm
See my earlier post on the alignment specs before and after. Had my indy go over every nut, bolt, screw, etc.
Thanks for your offer. This will get sorted out.
That is what I am leaning towards. Did not get a chance to check the front springs last night.
  #38
Old 04-23-2013 | 11:50 AM
IF i recall correctly. I have 650 front spring rate and 1020 or 1050 rear spring rate.
The car ATM with a new alignment is very neutral for my style of driving....I do not have my front splitter on though. I suspect once my front splitter on it will be neutral but bias to oversteer which is what i prefer.
I know Dez ( heavychevy) has commented in the past that a mismatch spring rate so far apart causes a lot of oversteer....but my driving suits it... so perhaps that is why i cannot tell ? ... that is my only guess at this moment.
  #39
Old 04-23-2013 | 12:12 PM
996TWINS's Avatar
The rear springs 170 N/mm which equals 970 lbs/in.
N/mm X 5.71= lbs/in, correct?
I will check the front springs tonight.
  #40
Old 04-23-2013 | 12:15 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
You may want to get your alignment checked again.
On some car with the escentric bolt, the alignment will slip during hard cornering causing the alignment to be off. I'm not sure what the torque specs are on the 911, but sometimes they are much higher than the typical tech will tighten them by hand.
As soon as you go into a turn aggressively and accelerate hard, the rear toe will be off again, as it was previously.
Get your alignment rechecked. If it's off again, make sure they look up the factory torque specs and torque the ecentric bolts appropriately.
Later, Steve
  #41
Old 04-25-2013 | 12:33 PM
996TWINS's Avatar
Later, Steve
The car has the locking toe plates.
Last night I finally got to check out the front springs, which are 685.
So the fronts at 685 and the rears at 970 are in balance (200-300).
Looks like the car is going back to the shop who did the original install.
  #42
Old 04-25-2013 | 02:15 PM
Definitely strange, given your spring rates and swaybars, the car should understeer more than stock. Of course your alignment is more aggressive, but it still doesn't make sense.
Good luck,
Steve
  #43
Old 04-25-2013 | 10:56 PM
996TWINS's Avatar
Looks like I found the problem, the bumpstops up front are too long. With little travel of the shock available, since it sits lower than stock it bottoms out, and the spring rate goes to ∞.
You were correct!
My shop will take care of this next week and set my car up at a nearby track
  #44
Old 04-26-2013 | 11:24 AM
heavychevy's Avatar
Definitely strange, given your spring rates and swaybars, the car should understeer more than stock. Of course your alignment is more agressive, but it still doesn't make sense.
Good luck,
Steve
A 300 lb difference in front rear will be more prone to oversteer than understeer. If its not an alignment issue I would try playing with the rake. Do you have a side profile shot of the car sitting still? Is the understeer slow and progressive or does it snap sideways? If its slow, then likely setup involvex. If fast more than likely toe related.
900 lbs is too stiff for no real downforce and on r888's. Your car cannot set properly and grip.
Enrique your car is very tail happy because of that enormous spring rate gap. Thats nuts.
I would set everything to the middle setting and start over by adjusting rake first. You can do this on your own at the track but if you dont know how to having a knowledgable mechanic with you will do. Start by lowering the rear 1/2 to 1 turn. But try and work on the end with the issue first if you can. If it gets close then play with rear sway and then shock settings.
  #45
Old 04-26-2013 | 11:55 AM
996TWINS's Avatar
Heavy, looks like I discovered the problem. See post #42.
I will be using NT01s after this set of R888s.
