Donuts in AWD?
#31
assuming its been repaired right, you won't be disappointed
If I wasn't in winter/salt zone, would DD mine year-round...
#32
Cool.
I havent decided yet, what settings my lsd should have. Like the 996GT2/3 40%/65% or like the 997GT2/3 25%/40% 15 Nm preload.
Limitations in everyday use with the 6GT2 LSD?
#33
you want a minimum of 6GT2 settings, 997 is too low. Full track is typically a 50/80 lock-up, although some prefer the looser 40/60 for rotation..
Zero issues DD'ing a 40/60, don't go crazy on preload
#37
PSM was off of cource. -2 degree camber front and rear with pss10 10/10.
Tires were michelin ps2 in stock size.
Well i didnt want to raise rpm so much in first gear. The car started to spin over 6000RPM. I didnt want to give the rack any more turns....
#39
ghost, timing is off 180*, soon as you have front end grip you want the rear breaking free, set the front end and let the rear end out and be on power, all about weight shift in 911's, use it right and bliss...,,, LSD or open diff in vids? looks open....
as always, I'll say it, drive 911's like a kart...
#40
Still got an open diff, which doesnt make it easier.
#42
yea, not enough gas, while my donuts weren't in a perfect circle, you'll notice i don't let off, when it would start to grip i'd just give it more.........throttle control...then steering control
#45
Bringing up an old thread.....
I'm so used to doing donuts in my Miata. And now that it has been sold I haven't done donuts in about a year. I have not tried it in the 997 Turbo. I thought that there was just too much "stick".
Its time to give it a shot.
