Results switching from a stock Y-pipe to a 3" custom one
Old 04-21-2013, 06:41 PM
HBK's Avatar
HBK
HBK is offline
HBK is infamous around these partsHBK is infamous around these parts
Baseline was done a few days prior. The new Y-pipe was completed and NO changes were done to the car through the boost controller or the tune. Just strapped back on and ran again...
Setup:
Stock motor
Stock exhaust manifolds
74mm ipd plenum
74mm tb
HTA 3071
E85
1.6 bar
Before: 607/596
After: 607/643
Old 04-21-2013, 09:46 PM
MikeG's Avatar
MikeG is infamous around these parts
Looks Great! Fantastic gains as well.
Old 04-22-2013, 06:57 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Hey so you gained a lot more of torque? thats awesome.
Old 04-22-2013, 10:05 AM
johnspeed's Avatar
Great,,Nice improvement...
Do you think on 93 pump gas with the lower boost to match for that fuel,,It would have been that good of improvement also with that large 3''??..
IMO, I wouldnt think so..
Keep up the good testing..
Old 04-22-2013, 10:13 AM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Did you happen to log boost?
Old 04-22-2013, 11:30 AM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
I would be interested as well. It looks like a little like a little boost spike as the turbo spools up since your peak torque went up, but your peak hp did not.
Bigger intake piping should give you more top end power instead of bottom end torque.
Later, Steve
Old 04-22-2013, 01:03 PM
johnspeed's Avatar
From what I have seen,,most guys at mid level stage +lower boost then his, get better results all around with a 2.5'' pipe..
Old 04-22-2013, 01:06 PM
HBK's Avatar
HBK
HBK is offline
Later, Steve
If you look at the overlay the hp and tq did not change up top. You are saying peak torque went up which is true but the car also made a substantial amount more hp from throttle input until 6100 rpm. Same with torque.
The car feels much more responsive and frantic on the street. I love it.
Old 04-22-2013, 01:14 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
You have a PM. Please check it.
Old 04-22-2013, 01:28 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
If you didn't gain power at peak, did you gain under the curve?
Can you post before and after dyno charts?
Old 04-22-2013, 02:09 PM
What was the connection at the Y pipe to ICs... 2.5? OEM? or 3"
thanks
Markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 04-22-2013, 02:20 PM
Tim941NYC's Avatar
The torque limiter could be set in the ecu. I think that maybe the case as their is stock rods? good test and back to back. For my info, stars and moon in the same alignment for both dyno pulls? haha...
Old 04-22-2013, 02:41 PM
layinback's Avatar
layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !
Having a custom Y pipe built now. I had an aftermarket 3 inch job
but it never fit! In between boost leaks it was awesome
I had Markski take it off because it took an extra 2 hours to do
anything in the engine bay and I was tired of hearing Markski
cursing out a Y pipe lol.
I can attest to the difference it makes. I'm not one bit surprised
at the power under the curve and the massive torque gain.
Old 04-22-2013, 02:42 PM
HBK's Avatar
HBK
HBK is offline
PM sent.
Did you watch the video Bobby? Dyno plots of before and after are at the end of the video.
thanks
Markski
Forge 2.5" outlet intercoolers going to a 45 degree 2.5 --->3.0 silicone coupler.
Lmao
Old 04-22-2013, 02:49 PM
johnspeed's Avatar
Hi,What level of mods do you have...Thanks
Quick Reply: Results switching from a stock Y-pipe to a 3" custom one
