Injector circuit fault code Frustration
So my build project with K24/20, IC, and 72lbs injectors have turned into a PITA.
Ever since the install was done, I have not had the opportunity to data log the vehicle for EPL other than a of the shelf flash and a little tweaking. Friday car ran rough coming from airport and durametric showed P206 Fault code 151 injector cylinder 6 . I clear the code took a couple of times and car ran fan, no codes seen. Didn't drive it at all, started her up on Sunday, no problem. Come monday, code came on again, had vehicle brought down to my pcar shop in sacramento. Got called today after they had swapped from cyl 6 to cyl 4 and code traveled with it. This is frustrating , never heard of new injectors failing intermittently.
Now have to wait for all parties involved to help me solve this, in the mean time she just sits there and the weather is so nice .
im battling the same issue . mine is cyl 1 and cyl 6. after many swaps, (coils, plugs twice, injector wire chasing the only common thread is the dme itself. i am replacing the oem dme with another used unit the epl is swapping all the data on. hoping it fixes my open circuit as well.
WheelsupZR1
09-19-2015 06:46 AM
Emre@Esmotor
09-09-2015 08:48 AM
