A rattle ... not good...
Old 05-18-2013, 10:03 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
It's hard to tell from the video, but it does not sound that bad to me. As far as I can tell, rattling sounds at idle are pretty normal for our cars.
  #32
Old 05-18-2013, 10:10 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
All these engines seem to have a bit of rattle but that does sound different??
  #33
Old 05-18-2013, 10:23 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
OK so. I looked around some more. Sound / rattle does not disappear when I press the clutch but strangely enough, when I started the engine from cold tonight it did not make a noise, it was really smooth as always.
So I did notice over the last few months that once or twice, in the morning, with cold engine, the clutch was grabbing at a totally different point. I needed to release the clutch almost to the top of the travel before the clutch worked.. I specifically can feel it when I reverse out of the garage. So now I am hoping this is connected somehow. I have no leak, no pentosin sloshing around from what I can see but I did not look at that in detail.. I have an appointment with my indie on Monday. Ok boys.. show your knowledge.. and tell me what is wrong.. Damn, I will have to go and offer my services to the rich ladies again to pay for the Porsche habit!!!! That gets old very quickly..
  #34
Old 05-19-2013, 07:51 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
Your Dual Mass Flywheel needs replacing
  #35
Old 05-19-2013, 09:57 AM
Macster's Avatar
Turbo internal engine issues are rare. Sure there is the exception but before you trash the car let the indy do his job.
Let the indy listen to the engine. He'll get the car in the air and he'll use a stethoscope and pinpoint the source of the noise and from this get a good feel for what's wrong.
  #36
Old 05-19-2013, 10:11 AM
hroussard's Avatar
Thanks guys.. I am booked in for tomorrow morning.
  #37
Old 05-19-2013, 01:35 PM
metzos's Avatar
metzos is infamous around these parts
sound like loose intermediate shaft bearings...(had something like this back in 2006) and it was only noticable on idle. Better to check it..
  #38
Old 05-19-2013, 02:19 PM
'02996ttx50's Avatar
Originally Posted by mikerosi
These guys listening on ytube ...................
.its crazy I tell you
BTW you owe me a talll beer, Mike
mike
ya see? told ya. fun game, right? ( apologies to the OP ) but only carnac knows for sure..
as for me.. i'm giving odds on it being ims issue as metzos; our greek bearing bearing stories suggests.. any takers?
Old 05-20-2013, 10:16 AM
Pmafia's Avatar
Pmafia is infamous around these parts
The sound is totally normal. Eventually all 996tt/997tt develop this noise. It's the IMS gear and how well it meshes with the crank gear. The more backlash you have between the two gears, the more you will hear this sound. You will not hear it on cold start, only when the engine is warm. The sound should go away if you rev it above 2k rpms. Monitor you oil filter for metal, you have to cut it open and spread out the pleats. Look between the pleats.
The reason why you hear it at idle is because the engine firing pulses at idle speed up and slow down the crank quickly and that's where the backlash comes into play. There is a thread on 6speed where a guy tore apart his whole engine just because of that noise. He ended up finding nothing. Put in a new IMS gear with less backlash than the old one and it was much quieter.
https://www.6speedonline.com/forums/...aft-noise.html
  #40
Old 05-20-2013, 10:21 AM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Originally Posted by Pmafia
The sound is totally normal. Eventually all 996tt/997tt develop this noise...
Jeez, I really hope this is incorrect.
-V
  #41
Old 05-20-2013, 01:02 PM
regrossman's Avatar
regrossman is a jewel in the roughregrossman is a jewel in the roughregrossman is a jewel in the rough
Sounds normal to me.
  #42
Old 05-20-2013, 03:00 PM
you guys must all have better ears than i do. it sounded horrible to me... and the guy thinks it's gone from "normal" sounding,.. to crawling around under his car making iphone vids. i just hope my car ( 104k miles now ) never sounds like that.
  #43
Old 05-20-2013, 04:55 PM
hroussard's Avatar
And... here is an update...
With special complements of the Pentosin boys at Porsche in Germany, the system started a small leak. So a new vessel has been installed. They believe it was the sound of the pump that provides pressure to the Pentosin reservoir / system that made the unusual sound . I am picking up the car tonight and we will see if that took care of the problem. One more chalked up to good engineering! And yes, I know there is a GT2 replacement option to rip and replace the Pentosin system altogether. Next time Baby ... next time.. there will be a next time for sure!!
  #44
Old 05-20-2013, 05:58 PM
With special complements of the Pentosin boys at Porsche in Germany, the system started a small leak. So a new vessel has been installed. They believe it was the sound of the pump that provides pressure to the Pentosin reservoir / system that made the unusual sound . I am picking up the car tonight and we will see if that took care of the problem!
the what!? lol. are you talking clutch slave/accumulator?? or the power steering reservoir!? i gotta know man. ( or do YOU even know ) i've got bitcoin on this sh*t .. that didn;t sound like any pentosin leaking item to me. but i think i've been had. such is the danger of "guess that sound" ha. but all kidding aside. good that you dodged a bullet. ( ps what pentosin boys in germ.... ) never mind
  #45
Old 05-20-2013, 06:18 PM
hroussard's Avatar
The Clutch pressure Accumulator ( looks like a little black ball) . Seems there is a pump that pressurizes that system and when that gurgles.. well you know the rest. You lost your bitcoin.
Quick Reply: A rattle ... not good...
