Clutch slave or accumulator?
I had the same symptoms, minus the leaking. Last season my PS fluid was low. At the beginning of this season I had the high pitched whining in 1st and 2nd gear and the clutch pedal was very stiff when cold. After a few miles or pumping of the clutch pedal it felt fine. I read lots on here that it was the accumulator. My indy mechanic suggested replacing the slave at the same time so as not to incur the labor costs again. I think the total repair costs for parts, materials and labor was around $900 for the stock clutch. What a nice smooth feel like it should be.
That said, I'm probably going to run a 997 slave and accumulator and a Sachs 2.5 when the time (unfortunately) comes...so I may be biased.
If I don't want to do the GT2 upgrade, it sounds like I should use the 997 Turbo slave and accumulator as a minor upgrade? Is that the right move?
Anyone have those part numbers handy?
Correct me if I'm wrong, since I have no experience with an aftermarket clutch (but have been heavily considering it and searching these forums incessantly), but it seems like the 997 slave and accumulator would survive just fine with a Sachs 2.5 which isn't TOO too heavy. The people running a heavier clutch are the ones that are seeing immediate failures with non GT2 conversions. That's what I've taken from all of this anyway.
Good Luck
When I repalced my slave and accumulator for the third time I used the 997 parts. They faired no better that the 996 parts. But your results may differ. But I have had zero issues since I went to the GT2 set-up.
Agreed - convert it and be done. No future headaches.
jaehoppa
10-22-2015 10:17 PM
