Fuel return line where to plumb from?
I am running Oem pump with inline 044 with dash 8 feed lines. I just put new pumps in and I'm seeing 145psi base with 044 running. With just front pump on I'm seeing 60psi which is close enough to the 4bar reg. turn on 044 it slowly climbs to 145psi. On the dyno once you roll into it pressure will fall back to 60psi by 5000rpm and hold.
I'm guessing I need a dash 6 return line? Where do most run plumb the dash 6 from? Should I keep cooler in line and plumb after that?
At idle it should be about 53 psi.. 3.4 bar... thats assuming you are on a OEM FPR...
check immediately the the black plastic line going to the FPR... the vacuum line... if it popped off at the rubber connector it will run 60 psi at idle...
fuel pressure is 1 to 1 ratio so it should go up with boost... if not you have a major blow up problem so be careful...
2001 996TT 3.6L and stock ECU
Running 4 bar bosch reg in factory position.
What pressure do you see at idle when you put an inline 044 in?
Mine was not at wot but at idle. Have you put a pressure gauge on it to see what's what.? It's the only way to really know.
The tune is set the lambda to (.80) !!!
I think i may installed the elctronic wiring wrong or FPR hose is bad or connect to check valve .. Etc etc !!
Whats the size of fuel hoses should be ? Am useing 6AN hoses and 6an fittings !!!
At idel the car is fine , but WOT lambda go rich (.73)
adnanm3
11-22-2023 02:43 AM
