Oil change ... More power now.
Old 07-16-2013 | 09:50 AM
jpflip's Avatar
Originally Posted by '02996ttx50
i agree, it doesn't make sense on paper. but i've never heard the "screech" that sometimes occurs at hi temp startups, that i have when the 0-40 is in. has ANYone ever heard this momentary lack of oil on startup? or is it only my car? it's only when the engine temp is high. not from a cold start. very strange and only last a second, then oil pumps and all is ( presumably ) coated again.
I do have this clatter at start for a second or two but only with the engine cold. Even after replacing the check valve at the bottom of the tank, even after going from Mobil 0w40 to TDT 5W40 I still got this strange behavior. But only when cold or car was left for a day or two without starting....
  #77
Old 07-16-2013 | 09:52 AM
'02996ttx50's Avatar
thx jp. a clatter i can take. it's the rare *screech* that worries me.
  #78
Old 07-16-2013 | 01:09 PM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
I would bet you way more then a nickel that the Screech is not a result of any oil issue!
  #79
Old 07-16-2013 | 02:38 PM
it sounds kinda like the sound of a wet serp belt that last a sec after the engine comp gets wet. only its metal apologies for this diversion. i mentioned it only relative to oil and that the lower viscosity/heat seems to be causal. it's a horrible sound. really. but it has only happened as i described while ambient temps are 100+ and it's instantly quieted once oil is pumping. i've never had it happen while using my usual summer fill of 5-40. i'm sure i would have noticed.
it's probably best i don't know what causes it
  #80
Old 07-16-2013 | 06:54 PM
Engine Guy's Avatar
Ahhh yeah!!!!! The old wait till it fixes itself or blows up technique. I have used that one myself a time or two.
  #81
Old 07-16-2013 | 07:19 PM
lol..the obverse of paying someone to tear my engine apart to look for the cause of a screech that happens once or twice a year and only when it's over 100 degrees outside..
think i'll go with.. "it never happened"
  #82
Old 07-25-2013 | 11:06 PM
Dr_jitsu's Avatar
Originally Posted by PAULIEWALNUTS
I run 0w40w mobil 1 with 2 bottles of BG MOA zinc additive. My car has > 700 rwhp & it lives in my garage 100% of the time.
Fixed
  #83
Old 07-26-2013 | 01:11 PM
Fallbangskid's Avatar
Fallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud of
I have a similar sounding noise that is mechanical that lasts about a second after I start it cold. In my case I think it is the starter gear retracting and making a "whurrrring" kinda sound. I have it too and think mine's "normal".
FBS
COBB Tuning
01-29-2022 09:42 AM
SharkyShark20
09-19-2015 09:54 PM
BLKonBLK911C4S
NorCal
08-29-2015 03:20 AM
gulf gt
08-27-2015 10:27 AM
00aston
08-27-2015 12:01 AM
Quick Reply: Oil change ... More power now.
