Oil change ... More power now.
Old 07-10-2013 | 06:20 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
The car felt low on power mainly at low and mid. Maby I was making it up. It's hard to tell some times ... I sware this use to have more power... Changed the oil Friday from a 10w30 to 15w40 royal purple for both after 3000 mi before a Saturday auto cross . What the hell. This thing has twice the low and mid range now.. Must be the variable valve timing wasn't working right and maby the clearance in the turbo bearings is a little large.
Old 07-10-2013 | 08:16 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
It's in your head me thinks...
Old 07-10-2013 | 09:01 PM
raineycd's Avatar
Did you disconnect the battery?
Old 07-10-2013 | 10:07 PM
djantlive's Avatar
10w30 for turbo?
Old 07-11-2013 | 12:59 AM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Twice the grunt now? Thanks for the joke of the day...
Old 07-11-2013 | 06:14 AM
pat's Avatar
pat
I am not kidding. I rebooted a day latter. The high rpm power was there before but that low rpm grunt was missing. Boost seemed to be there but not the grunt.
Old 07-11-2013 | 07:35 AM
johnspeed's Avatar
Wow, Sure it wasn't the oil filter change that did it... LOL
Old 07-11-2013 | 07:41 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Put some wax on it & really feel the power. Wax on Wax off = 20+ rwhp.
Old 07-11-2013 | 07:50 AM
Terminator's Avatar
On the oil filter you mean? :-))).
Old 07-11-2013 | 12:30 PM
rmc1148's Avatar
It has to be a joke as we all know an oil change will not make a noticeable increase in hp.
Old 07-11-2013 | 12:48 PM
johnspeed's Avatar
Plus,, when I did dyno testing on oils back when I had my bike dyno,, I saw slight gains going from higher viscosity oil to lower viscosity oil.. 15w50 to 5w30 made the most difference, 3 to 4 hp.
Old 07-11-2013 | 01:45 PM
wross996TT's Avatar
Correlation is NOT causation...let's say there really is a change in performance....you think to yourself...."Self, what did I last do?" And you answer "changed the oil"...therefore you conclude "It's the oil"...sorry you have a theory about what changed it, but nothing conclusive. My guess is something else changed.
Old 07-11-2013 | 02:03 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Changed the oil in my 318is today, oh boy. Afterward I went to the dyno, only to find that my ~95hp engine was putting out an astonishing 83hp. I changed the oil again, just to be sure, and would you believe it....???? It made 84hp!
Old 07-11-2013 | 02:40 PM
Terminator's Avatar
You should wax the oil filter then report back. :-).
Old 07-11-2013 | 02:56 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
You guys are brutal!!
It must be something else like raineycd eluded to.
Did you disconnect your battery?
This is the only thing I can think of that might cause something like that to happen. How was the weather compared to the day you did the oil change?
IE if it was hot and very humid (as it has been in Toronto) and then you did the oil change on a cooler and less humid day also makes a BIG difference in performance.
Just some thoughts.
Bobby Ali
ba
Quick Reply: Oil change ... More power now.
