Pictures of Sharky's Bent Rod....
Old 08-06-2005 | 02:46 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
i was afraid to click thought it was **** related hahaha!
Old 08-06-2005 | 02:53 PM
sharkster's Avatar
I would never do such a thing! I mean to abuse a goat is just wrong. Hampsters ok...
Old 08-06-2005 | 03:15 PM
mpwrmodena's Avatar
mpwrmodena is infamous around these parts
You cant go wrong with carillo, do they came with ARP rod bolts? Also do you plan on upgrading the pistons also?
Old 08-06-2005 | 03:27 PM
sharkster's Avatar
They don't come with ARP bolts but I got 'em anyways.. I got the motorsport pistons too
Old 08-06-2005 | 11:13 PM
TT Surgeon's Avatar
Shark, you need to define your cars objective. Is it a street car, a drag car or a track car?
I used Carrillo rods fore my low RPM (<8000rpm) endurance type engines, ie sprint cars, etc. Too much reciprocating mass for drag racing.
For all out drag racing, I would go with aluminum rods or titanium, just change them once a season, alot less reciprocating mass.
A street car, stock or carrillo's I guess, but it really doesn't sound streetable anymore to me.
As far as racing tires, don't f with anything with treads on it at the strip, You'll never hook up all that power. Hope your differential is up top the task.
Disclaimer, all my racing experience is limited to small block chevrolets, NHRA drag racing, sprint cars and the like.
My drag cars weighed 2800#,385ci SB, shift at 10k, cross the lights at 11k, 9:40's at 148ish mph with a '55 chevy body/tube chassis, carried the front wheels 60 ft, zero spin. My engines dynoed at 650hp.
If your car is making 700 hp on an engine dyno, and you're barely running ten's, you're not hooking up at all, all up in smoke is what it sounds like to me. You need to set up your chassis and tires somehow and dump some weight. Then you'll break the 10 second barrier. Good luck!
Old 08-07-2005 | 12:39 AM
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
I love the shelf, Shark. I have the same one.
Old 08-07-2005 | 03:29 AM
mpwrmodena's Avatar
SHarky, GOod move throwing the ARP rod bolts on there anyways. WIth the pistons get the tops ceramic coated and the sides coating with swain Poly Moly. CHeck out swain tech for pricing and what not.
Old 08-07-2005 | 11:08 AM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
I'm impressed that it did not fail. What caused it to bend? I'm guessing it was more power related than a detonation or over-rev problem. What kind of damage was done to the engine? What parts needed replacement?
PV=nRT.
09-09-2022 06:06 PM
goto35
03-08-2020 07:41 PM
joeyharp
08-29-2016 09:41 PM
BLKMGK
09-19-2015 03:51 PM
Quick Reply: Pictures of Sharky's Bent Rod....
