Turbo leaking oil into intercooler/boost tract.
Old 07-30-2013, 04:09 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Originally Posted by winnigt2
that is possible, i prefer to check oillevel only at real hot engine
No whoever is telling you this is wrong. For oil to get in your boost hoses means you have a turbo seal leaking.
Old 07-30-2013, 04:26 PM
rmc1148's Avatar
I have not fooled with my 996tt turbos as of yet but have quite a bit on A4/s4 and they have all had some oil in the inner cooler hoses for what that's worth lol.
Old 07-30-2013, 04:30 PM
rmc1148's Avatar
Meant intercooler hoses of course should not watch TV and type lol.
Old 07-30-2013, 04:50 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Originally Posted by TTdude
The thermal expansion coefficient for Mobil 1 is approximately 0.0005 vol unit/F. Thus, for a 50 degree increase in temp, 9 quarts of oil would expand less than 3%. So I don't think it would make a whole lot of difference unless it was overfilled to begin with.
Using your math, 3% of 9L is 270ML or about 1/4 of a Liter. Not much but if you had your car filled to the very top (max limit) how would you feel about putting in an extra 1/4?
Guess there is some logic to the statement...
996tt550hp's Avatar
Any oil in the intercooler hoses you need to have your indy check on your turbos. Trust me when i tell you don't let them get any worse if it is the seals.
Old 07-31-2013, 10:36 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
if you are simply overfill your oillevel you can get get oil in your boost hoses too, because the overfill line goes into the intake boost hose
Old 07-31-2013, 10:49 AM
996tt550hp's Avatar
Ummmmm plz take a pic because i see all of my hoses and no lines go in there.
Old 08-01-2013, 06:38 AM
winnigt2's Avatar
follow the small hole at the intakeplenum and you find your oiltank....pictures attached
and exact at this point overfilled oil at hot engine goes into the intake tract
ID:	266653   Click image for larger version
Old 08-01-2013, 07:15 AM
996tt550hp's Avatar
I just asked if we had and oil fill drain at Porsche they said no. I have over filled mine and I never had any oil in my pipe so I recommend to get your turbos checked.
04-28-2022 12:38 AM
stevenrmusic
Bentley
17
11-12-2015 05:53 PM
tropicatango
10-14-2015 11:32 PM
Senatorblutarsky
08-28-2015 12:44 PM
Lucid Moment
08-20-2015 02:22 PM
Quick Reply: Turbo leaking oil into intercooler/boost tract.
