Turbo leaking oil into intercooler/boost tract.
I seem to have an internal leak on one of my 18g billets. The turbos seem to have the same amount of play in them, but only one is leaking. It leaves a puddle of oil when I pull off the turbo outlet hose. Could I have a bad check valve or a leak somewhere? Any ideas? Thanks.
I have new A3076 and I see a small oil leak only at the drivers side.It must be normal.
I asked Sean at the shop and no it is not normal to have oil in any pipes or puddles. My pipes are dry.
Never heard of that.
I always heard to use new check valves when swapping turbos. Not sure why exactly, but I think they are pretty cheap from Porsche or Indy .
that is possible, i prefer to check oillevel only at real hot engine
The thermal expansion coefficient for Mobil 1 is approximately 0.0005 vol unit/F. Thus, for a 50 degree increase in temp, 9 quarts of oil would expand less than 3%. So I don't think it would make a whole lot of difference unless it was overfilled to begin with.
My car only lets me check the oil when it is up to temp. So doubt it will expand much more than the threshold my gauges will light up...
