2nd gear
2nd gear
My second gear pops out - I have read on the forum that it is most likely a second gear repair. can anyone help me by telling me what I would need to repair the second gear in the tranny? Much appreciated
Some info in this thread https://www.6speedonline.com/forums/...r-pop-out.html
are lots of threads regarding this if you search ;-).
Wrong! Yes it's the 2001 turbo. They fixed it in 2002 and up but yes still had some issues.
Thats not correct, even 997s have this problem often. I never had a problem on mine till i upgraded to 997 gt2 trans, i read about a lot of 997 gt2s complaining about this. And i tried the gbox from the very beginning, no help.. I will try to change trans mounts, check cables and short shifter and let you know after if i succeded
more conjecture disguised as "information". once again, you're completely wrong. many 02 tts have had 2nd gear popout. i get my info from personal experience. you?? lol
Wrong and wrong once again if you don't know something plz don't post. It was fixed after 2001 but still had some issues but not as bad.
OP, good luck, its a pretty expensive fix but once you get it done youll be happy you did it...
keep drinking tap water smart guy. it is clearly having the desired effect. in the meantime, don't make blanket assertions until YOU know what you're talking about ( which i'm going to guess isn't very often ) but have a nice day anyway
So, tell us how there were ZERO pop out issues in other model years. Go on.
Ok send me post on 2002 and up on here...... also never said zero pop out issues you put words in peoples mouth. I said the main problem was the 2001 turbos.
Ohh and on that note the problem was the 2001 turbos and other years had some issues but it was a low percentage.
