Problem with Leather Dash
The leather near the front defrost vents is starting to develop ripples/bubbles in it. I have seen other 911s with the same problem, any ideas on how to fix it? I wish Porsche Certified warranty would handle this but the the service advisor said it doesn't cover any interior pieces.. what a jib!! Anyone else experience this? how do you fix this without replacing the whole dash?
grrrrrrrrr
grrrrrrrrr
Did you get a warranty coverage paper? I thought interior is covered. I'd double check that and call Porsche or visit their site for detail. Otherwise, call another dealer.
I don't think there is an easy fix. You'll have to take out the piece that's bubbled and have it reglued on. Otherwise, you are looking at a new dash. Of course, you can always cover it up with a dash carpet but that's not a good look in my opinion. Did you leave the car in the sun a lot?
Originally posted by 1999Porsche911
Keeping the leather properly treated with condtioner wil help prevent this, especially when the car is in the sun alot.
There was a thread on rennlist concerning treating the leather on the dash. Here's what Dock posted:
'The leather Porsche uses on the dash contains almost no moisture - it is specifically dried so there will be less "movement" as it goes through the big temperature changes that can occur on the dash. Introducing moisture back into the leather by using a conditioner will cause the leather to "move" with temperature changes and possibly break loose from the surface it is glued to. Here's what Porsche has to say about the leather used on the dash...
"All leather is not the same. We work with classic upholstery leather, but we also work with low-shrinkage leather. The instrument paneling, for example, can get extremely hot in summer. If the material starting tightening, what would that look like after a while? So we're talking about leather whose residual moisture has been largly removed, which means that it won't be able to shrink later." (Christophorus, No. 276 January 1999)
I have not applied *anything* to my leather dash (3.5 years old now) and it looks good as new."
The consensus seems to be... leave the dash leather alone.
I leave the dash leather alone and have had no problems...
I am past the point of fixing it with a leather conditioner. I bought the car in Texas so that may be the cause. I always park it in the shade.
I will look in to the terms of the certified warranty and see what it says. Seems like it is open to interpretation by the service departments.
djantlive - it is the edge of the dash so it is not a seperate piece.
Have an expert look at it...you would be amazed at what they can do to leather. Good luck with Porsche.
My understanding of the Certified Warranty is that it does cover the dash. I had mine replaced on my 01 996TT when it bubbled up on Palm Desert last year.
The Certified Warranty does not cover small rattles and items of that sort. Press the issue.
I am getting deja vu regarding the conflicting opinions for leather care on the dash. I also do not know the answer, but there are a number of products that "restore" leather. Leatherique has a good product for this:
http://www.leatherique.com/
after restored, you might try sealing it (UV protection) with 303 Aerospace treatment:
http://www.303products.com/tech/index.cfm
evermore
09-29-2016 09:27 AM
manfred@loma_wheels
09-02-2015 12:22 PM
