330mm to 350mm rotors
Old 10-27-2013 | 07:57 PM
rabbit1445's Avatar
rabbit1445 is a jewel in the roughrabbit1445 is a jewel in the roughrabbit1445 is a jewel in the roughrabbit1445 is a jewel in the rough
So I am planning on doing 350mm rotors with the stock calipers and caliper spacers on all four corners. My rear pads and rotors are worn and ready to be changed, so I was planning on adding the larger rotors to the rear now and doing the fronts when they are ready to be changed. I am assuming this will work fine and will not negatively effect brake bias since the stock calipers are still in use? Any thoughts would be appreciated.
Old 10-28-2013 | 07:00 AM
curacaosfinest's Avatar
curacaosfinest is infamous around these parts
here you go bud!
Found this here:
https://www.6speedonline.com/forums/...h-fiction.html
i hope this answered your question
Old 10-28-2013 | 07:56 AM
it will not mess with brake bias since you are using stock calipers.
#TeamAIM
Old 10-28-2013 | 04:48 PM
pwdrhound's Avatar
If he has 330s on the front and changes to 350s on the rear, it WILL change his brake bias as the braking force is applied further from the centre on the rear (more leverage). I would upgrade to 350s on all 4 corners, not just the rears.
Old 11-09-2013 | 06:16 PM
rabbit1445's Avatar
On another note, does anyone know if the collapsible spare will clear the calipers with the spacers?
matt2ace
11-23-2019 11:38 AM
Glasgo
11-30-2015 02:37 PM
ECS Tuning - BMW
BMW Vendor Classifieds
10-28-2015 10:48 AM
ECS Tuning - VW
09-28-2015 03:19 PM
Quick Reply: 330mm to 350mm rotors
