Engine rebuild questions...
#61
now just imagine 8000rpm with a 3.15 1st gear.
#TeamAIM
#TeamAIM
#62
But there are a few that try to out talk or try to act like they are in the know,probably to be one up on others because they can write/talk good so know one questions them but others don't get the real info...
#63
Have fun with the question. I love to hear what others have to say.
Below is a pic of stock 100 mm liner on the left and a far stronger 102 mm steel liner on the right.
Here is a set of 105.7 mm liners prior to interior being bonded. Trick because 105.7 mm will not fit a Porsche case ...... unless the thickness of the liner walls are varied. Certain steels are also part of the equation to provide designed strength.
#65
If you look closely at the above pics you can tell which liner is nikasil plated and where nikasel was used.
#67
Another question, have you ever seen a Porsche turbo application nikasil liner larger than 100 mm? You can get Porsche NA (normally aspirated) nikasil liners to 102 mm which isn't really designed for turbo applications/loads. Throughout our build we never assume anything. Total calculations as to as to required strengths, plastic part mock ups and then final manufacturing is what is required to properly avoid weak links. Then ..... unfortunately we still seem to miss something.
#68
Sorry I don't know Porsche aftermarket parts like that,, not that knowledgeable in that extreme area of Porsche stuff.
A short rod will always put more side load on sleeves and a stroker crank will have a higher piston speed causing faster sleeve wear also..
Cast iron cylinders always wore out faster and contaminated the oil as they wore But that . 003 thick coating extended my life and made more power longer..
#69
Now I an not trying to argue .... just making a point. A stroker does not mean it has to have short rods. KA had a 82.4 x 105.7 motor. Ideally a 134.0 mm rod length should have been use. Short of a very expensive deck extension along with a longer (redesigned) timing chain) this was not possible. We should have limited the stroke to no more than 80.2 mm where we could have gotten by with a 131 mm rod.
We were able to stretch our rod length to just under 130.0 mm but that required eliminating the piston bottom ring to shorten the piston, designing a smaller diameter wrist pin using higher strength steels and applying to them a near indestructible coating called black like diamonds, offset small rod center lines to obtain a perfectly true center line and designing a thicker head gasket that would hold up to 2.6 bar. A lot of bucks for an additional 3 plus mm. We would have been in heaven with a 80.4 mm stroker. As it is our PR is around 1.58-1. Not bad but it should have been better. This mistake required that we lower our redline by about 600 rpm's. This after we designed and built single lobe turbo intake and exhaust cams with GT3 Street markers having a lift of just under .450 . I wasn't happy with the screw up as the original design provided for a 9400 redline.
#70
I use and believe in fitting the longest rod possible,, Smokey Yunick tech stuff.... LOL
But sometimes it's not possible, sometimes you only can do it if you move wrist pin higher and make shorter skirts which doesn't help reliability of pistons.. BUT YOUR porsche builds and parts are so different from my non-porsche stuff..
We are just gear heads talking shop talk 101..
#71
#73
So if steel rods are used along with the lighter GT3 crank, does anything need to be done to the valve train to safely increase redline to 7500 or maybe 8000? Stiffer valve springs perhaps? Would you need new cams or are the stock ones sufficient?
#74
#75
Have some pics of some real trick valve trains, but I've probably gone a little too off topic already. Sorry.
