Explain corner balancing and why I should do it.
I am going to do a track event in September and wondering if I should find someone to corner balance my car. I have no idea what this really means so someone please educate me.
I just had mine done, buddy.
A quick overview:
Basically, they put your car on 4 scales (one per tire/wheel).
The height of your suspension is then adjusted (LF to RR and RF to LR). The values (depending on if you want to account for the driver's weight) are then evened out. This accounts for ride height and weight and plays a large roll when at the track (the proper cornering weight during a turn for said vehicle, etc). Weight transfer during track times play a large roll in a tire's contact path percentage as well.
Getting the car properly balanced will help to fix/reduce said issues.
A quick overview:
Originally posted by buddyg
thanks, I kinda of figured it was done on individual scales at each wheel. Can I ask how much it cost?
Originally posted by joekimdds
what's more important? corner balancing or 4 wheel alignment? or do you need both? sorry for the questions...novice
actually...when you corner balance you change the ride height and therfore change the alignment settings such as toe and camber. So you should be doing the alignment AFTER you cornerweight your car.
dave w
dave w
my tires wear out on the inner lip leaving approx 7k miles of use in the rear with my 19's...will the corner balancing (b/c it changes the camber-toe) allow the rear tires wear evenly and essentially longer?
dave w
dave w
You can do a few things:
1. Reduce the negative camber (if you get behind your car, you can see your wheels "tilting" inward towards the car). The more negative, the more that they will tilt inward and the more that it will shift the tire's contact patch to the side.
2. Keep a higher air pressure in your rears (or at least monitor it). This will cause the contact patch (on a car with higher camber) to shift more towards the center...somewhat.
The diagram below should make sense as to why your inner tires are wearing:
i had my alignment done at lucent...they said it was normal that the car has that much negative camper and it's all under factory specs...but they never mentioned corner balancing...didnt know if that'll help or not
Some negative camber is good right? What have people found
to be a good setting front and rear?
I have my fronts at -0.7 I do believe. My rears are at -1.5.
