Making use of rear O2 sensor bungs for AFR gauge
I'm running cat delete pipes with the secondary o2 bungs extended to eliminate CELs. I want to hook up wideband sensors to these bungs for AFR gauges but I don't know if there's away to just remove the factory o2 sensors without causing problems. Since they aren't doing anything I'm not sure why I need them mounted in the pipe. I don't want to deal with having another pair of bungs welded in if I can avoid it.
Does anyone here know if this is doable?
Hi,
the extended bungs cannot be used as they put the O2 sensors out of the stream - that's why you don't get CELs. The error messages for after cat O2 sensors can be disabled in the tune and most likely are alredy, so you can have your own sensors there, but they have to be positioned like OEM and not extended.
Andreas
Andreas
I been researching this myself and there really isn't a definitive answer to it.
I was thinking of the new AEM multi-gauge with logging and running two wideband sensors. Right now I am just using durametric, just hate not being able to see it as my other builds.
Any specific interfaces you recommend? Or can the factory rear o2 sensors work with an aftermarket A/F gauge?
you need a afr gauge? why dont use your onboards o2 Sensors via OBD like your DME does?
Hi,
Andreas
Andreas
Ah, I see. I would ask the tuner if he has disabled the after cat O2 monitors and if so, I would just unplug the oem sensor and take them out.
These are no longer being made and trying to find one for sale is hard enough as it is.
This is exactly what I was thinking also. The other idea was just to weld bungs right after the secondary bungs. PLX is good stuff also. What setup are you using from PLX?
I know; I was asking about using the sensors that come with the gauge in the secondary bungs without the extenders. I am using PLX gauges and the AFR modules come with their own wideband O2 sensors. I just want to know if I can safely put the factory sensors somewhere in the engine bay out of the way but still connected to the car if I want to use the bungs in the cat delete pipe for the O2 sensors that come with the gauge.
I was considering having additional bungs welded in also but I figured why waste the ones that are basically sitting idle right now if I can make use of them.
I talked to my tuner and he said the rear sensors are still set up to function as stock other than having the cat efficiency codes turned off. I thought that was all they were for.
They asked me to unplug a sensor and send them any codes that come up as a result. I unplugged both rear sensors and nothing changed...no codes and the car ran fine. I have a feeling a code will come up eventually but if they really don't affect the way the car runs at all that is a good sign.
Yes, that's all they are there for: checking if the cats are doing their job. Only the pre cat O2 sensors are affecting the cars performance. The ECU is monitoring and adjusting fueling with them.
Right now just the PLX-100 ODB with no additional modules. It is pretty nice as a standalone just watching ODB 2 parameters but I really want to add a boost module and a pair of AFR modules. That is where this gauge shines in my opinion. I was considering having additional bungs welded in also but I figured why waste the ones that are basically sitting idle right now if I can make use of them.
04-28-2022 12:38 AM
PenguiN
09-15-2015 11:44 AM
turbotuner20v
09-11-2015 12:02 PM
