E85 Fuel Kit?
#46
I really believe these cars are at their most fun at 7-800 whp. But to compete at these roll on events 800 ain't gonna cut it.
#47
I'm getting anxious myself. .just glad I went with the ProEfi. So much more control. Everything is happy but the fuel. Hopefully it can be addressed soon. I'm glad I'm with somebody that knows the system.
maybe 170 but the BIG horsepower trumps up top.
With a taller 6th and shorter 5th, I figure this car will do around 215-220 in
the standing mile but that's not gonna cut it these days.
#48
So you have 6 fuel pumps? A fuel system is just that, just because your pumps are individually rated to handle the fuel flow need does not mean that when pumping against head psi of other pumps, lines, fittings, filters and rails it is still the same out put. Also as each pump runs it draws down on the battery and makes the alternator draw more hp.. Steels volts and available amps from you ignition system.
Who knows what the 3 (or 6?) pumps are doing to your fuel quality. Are your large injectors pulsing the fuel in the rails? The only real way to know is to log your car. Fuel psi at furthest point on rail and fuel temps but that still does not tell if you fuel is being aerated.
#49
he really does know the system well and there is some new stuff that just got released in ProEFI that we will benefit from
have you tried it ?
have you tried it ?
#TeamAIM
#TeamAIM
#50
to!
So far a 800 hp evo, couple modded z06, a modded zr1 and a stock Hayubusa.
My car weighs just a hair over 3000 lbs. It's gonna be hard to keep up with
my 3.3 hp to weight ratio down low.
#51
Then you have an invite to Houston to run toe to toe with a 1000hp Porsche. There are 10 to choose from and we have events in Mexico weekly. I think drivers source has at least 5 cars.
#52
Plenty of Porsches here but nothing like our cars. This is Bama and
it's all about muscle cars!
04-28-2022 12:38 AM
turbotuner20v
09-11-2015 12:02 PM
