Car Sputtering at WOT
Old 12-13-2013 | 05:30 PM
scsponger31's Avatar
scsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to beholdscsponger31 is a splendid one to behold
On my way home from the office, I discovered how to replicate it every time. If I floor the car from a stop it will not sputter. If I floor it from a roll (either in first or second) it will sputter right around 5k rpms.
I really have a love hate relationship with this car.
Old 12-13-2013 | 07:00 PM
Tim941NYC's Avatar
Originally Posted by scsponger31
Looks like I need to spend more time going through the car. Where would recommend starting on my search?
I would start by removing the air box and smoking it. Take the oil fill cap off when you do it. Gas cap also.
Old 12-13-2013 | 10:13 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
This happened to me everytime i floor it on a roll it sputtered so i listen to Markski advice and he said it is your FPR hose it has fallen off on the FPR regulator. Sure enough he was right and the sputtering stopped. Mine too still had full boost showing.
Old 12-13-2013 | 10:55 PM
Ill have to check that too!
thanks!
Old 12-14-2013 | 01:41 PM
Completely went through the car this morning and everything is as it should be. Not sure what my next move will be.
Old 12-14-2013 | 02:31 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
Originally Posted by Tim941NYC
If you have no boost leak then you have a leak between the MAF and the inlet of the turbo.
read exactly what tim is asking you...its maybe not a boost leak, it could be a leak between the maf and the inlet of the turbo...check it
Old 12-14-2013 | 05:56 PM
I did the best I could without a Smoke Tester.
Here is something interesting though. The car absolutely will not sputter with the PSM off, it just tried to make it do it for the last 30 minutes. I had a Mercedes that the traction control would turn on by itself due to a bad Yaw sensor. Is this a possibility?
Old 12-15-2013 | 11:04 AM
Tested my theory again. Traction control on, car will sputter. PSM off pulls hard. Either way the PSM light does not flash ever. Any thoughts? I am officially confused.
Old 12-15-2013 | 12:30 PM
996tt550hp's Avatar
You need to do a full boost leak test and smoke test you have a leak somewhere or it might be a coil. Data log it with miss fires and see if your getting any. If you are then theres your issue.
Old 12-15-2013 | 12:50 PM
This very well could be ignorance on my part, but why would turning off the psm impact a leak or coil?
Old 12-16-2013 | 08:12 AM
The car also will not do it when I go back to the stock setting on my tune.
Old 12-16-2013 | 08:58 AM
wross996TT's Avatar
Since it is potentially tune related, perhaps you are running out of fuel...have you made any upgrades to the fuel system?
Old 12-16-2013 | 09:05 AM
Ironically that was was the first thing I said you need to look at along with the Maf.
Old 12-16-2013 | 09:12 AM
That is true! Do you think this is something that could happen over time with a Tune?
The fuel system is stock. I suppose it is very possible, but do you think this would occur all of the sudden with a tune?
Old 12-16-2013 | 09:14 AM
Log the car. Spend $390 on a cable b4 it's too late.
Markski
Quick Reply: Car Sputtering at WOT
