Good E85 vs Bad E85?? Gas Stations?
No I'm asking what people thought if they found, let's say perhaps that the Sunoco e85 was consistently better then let's say Valero. That's what I was asking. I know a lot of talk about winter and summer blend but then there are lots of people that don't think there really is a difference.
Also at the same extent a standalone isn't needed at my power level, plus you have no idea if I'm using the stock ecu. Btw there are people disagree with you in relation to tuning and using the stock ecu to help make a tune better by adapting. No one makes a perfect tune. Tim ur a builder not a tuner, let's keep it at that.
Btw I will find the thread from 2 years ago I read a week Ago u disagreeing with Tonys tuning and riding the knock sensor.
I would appreciate if u stayed outside my threads because u have had personal issues with me since I did NOTchoose u to do my build even though u live around the corner......for numerous reasons I would rather not say on a public forum for your benefit...
My benefit? As I always say it is the owner not the car.. You where crying the blues about the car costing you 4k in the first month you owned it, I told you come on by and I will help you change your radiator. Did I charge you? Did I look over your car and point out a few things? Did I stop your over boosting? You picked my brain then took what I told you and looked around for the cheapest prices on everything. You even went to shops and tried to get all the shops in a bidding war to work on your car! Something to think of.. Is the shop you got the best deal from warrantying their work or guaranteeing their work? No one I know would warrantying anything that they did not source themselves. Do you go to rare650 and bring your own steak for them to ccok? I know why they wont cook your supplied steak tho, when your meal sucks you will blame them. All the best.
Tim,
I don't want to put personal info on the internet for your benefit. I will leave it at that. FYI you quoted me a full build including all parts for 12.5k. Great price, didn't want to work with you. I'm sorry.
I think its best for our benefits that I just block you so I don't have to deal with your constant badgering and condescending comments u make in various threads towards me. Best of luck.
I will try to pull it up the article. Tested the same beginning to end but it was stored in proper dark area like a garage and it was sealed after each use.
I was also wondering if people keep some e85 on site at their house what they are using to refuel their car with……..I found this one product……
http://www.flo-n-go.com/products/product_duramax/
I guess I was looking at it as a dispensing unit more so than storage. Do they make a unit that can be hooked up to dispense from a metal storage container, thats not ur old school syphon?
The advantages of a truly flex fueled car running proefi or syveccs or whatever EMS with a flex fuel sensor will shine through here. They will not only monitor the ethanol content but will allow for real time changes in the map to accommodate them. Without speeding the money on a stand alone system, you can get a zietronix sensor with a display that will tell you what your ethanol content is at all times. I've used ethanol on all my cars and listen to the advice given, store it in the metal container it comes in and get a tester because the last thing you want is to use a batch of e85 that's really a winter blend and more like e65 and pop the motor.
As for your original question, e85 is rarely truly e85. Ive found it as low as 65 and high as 90 depending on the station and the time of year. The local station to me some days is 80 some days is 75 during the summer and during the winter it just gets lower.
Thanks bud.
I was looking into ordering some pure E85, a 55 gallon drum and storing it in the garage so I have it on call. I have a shop here, SK speed that can get it for me. Then after I use it all I would refill at a gas station when the readings were high or order more from time to time. The nice thing is there are ALOT of E85 gas stations on long island and some of my friends are already ahead of me in the e85 game so they know what stations already read higher and they run some aggressive e85 tunes (not porsches).
I Know I am blocked... Be careful of E85. E85 should be 85% ethanol and 15% gasoline. When you buy E85 do you know what it was cut with? usually its cut with 87 oct at the gas pump, but when you buy in a drum from unknown sources you most likely are getting reclaimed ethanol from the medical industry mixed with who knows what. As I stated earlier this is a question for your tuner. Put your block back on as it did not work
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
For what it's worth, Eddie Bello uses Ignite.
Not sure who SK Speed is buying from, but VP Racing, Ignite Racing & Rockett Brand all sell E85 Race Fuels (Ignite sells E98 also). AND you can also buy E98 from these guys in 55 gallon drums.
VP makes C85. gotta tune for it, you dont just dump it in. on another note have you checked that your injectors are compatible with C85 ??
#TeamAIM
#TeamAIM
